cooling system bleeding procedure - SR20 Forum
Old 06-27-2002, 08:54 AM   #1 (permalink)
going to flush out my cooling system...i heard somewhere a certain procedure is supposed to be followed, any ideas what the FSM says, since i dont have one ?
Texasbangerz is offline   Reply With Quote
Old 06-28-2002, 05:17 AM   #2 (permalink)
anyone, anyone ?
Old 06-28-2002, 06:02 AM   #3 (permalink)
Back in action 2/28
Got it frome the sentra.net
A good drain flush and refill will restore the coolant's recommended fluid ratio and prevent corrosion build up in the coolant system. Make sure the engine is cool before draining the system. Move the temperature knob on the heater control to hot. Remove the plastic shrouds under the radiator to locate the radiator drain. You'll need a large phillips screwdriver to remove the plug. Get a large drain pan under the drain to catch the fluid. Once the fluid stops draining, move the pan under the block and remove the air bleed plug (the GA16DE engine has an air bleed plug at the end of the cylinder head below the inside distributor retaining bolt and SR20DE models have a bleeder plug on the thermostate housing). This allows the coolant to drain out of the block. While draining, check the coolant hoses like the Cooling System Check above. Use a garden hose and flush the system with water. Flush until the water coming out of the drain is clear. This should remove any loose sediments. You should also buy a chemical cleaner specially made for flushing coolant systems. Follow the directions on the cleaner you purchase to perform a good flush. Be sure to empty the coolant reservoir and clean the components of that too. Install the radiator drain plug and fill the system until the radiator is full or the coolant is commong out of the air bleed valve. Install the air bleed valve and fill the coolant reservoir. Start the engine with the radiator cap off. Wait till the thermostate opens and starts circulating the fluid throughout the engine. Keep adding fluid while it takes it. Once the thermostate closes, the fluid will stop circulating. Just wait till it opens before adding more fluid. Squeeze the upper and lower radiator hoses to purge any air bubbles. When you get to a point where you can't add any more fluid, install the radiator cap, shut the engine off and allow it to cool. As the engine cools it will suck fluid from the reservoir to fill the rest of the system. Make sure you add enough fluid to the reservoir. Once the engine is cool, remove the radiator cap and check the level. If you have too much air in the system, fluid will not be suctioned into the system. Top of the radiator and the reservoir if needed. Run the engine and fill the system until the fluid level maintains the full positions on the reservoir.
Please checkout www.sentra.net for more info. and details.
Hope this helps.
Turbo 1995 200sx SE-R
especse_r is offline   Reply With Quote
Old 06-28-2002, 06:39 AM   #4 (permalink)
wow, thanx....
Old 06-28-2002, 09:30 AM   #5 (permalink)
pwnd
well thats sorta correct. the sr20 also has a bleeder plug on the block behind the exhaust manifold. also if you have an early classic like 91-92 you should have a rear bleeder up on the fire wall. my 93 doesnt have it ***.
usualy you pull all the drain plugs even the block one, then you can try a flush with running clean water though the block and radiator. then to fill it back up keep adding fluid until the lowest hole starts peeing fluid. put that bolt in, then move to the tstat housing bolt wait for it to start to flow. then if you got the rear bleeder wait for it to start peeing...
-Kevin
We are a community
Old 06-28-2002, 09:42 AM   #6 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
http://www.se-r.net/heat_ac/coolant.html
Also, there is no bleeder on the block. Only the one on the thermostat housing, and on the '91 and '92, the one near the firewall. the '93 and later cars only have the thermostat housing bleeder.
The community is here.
Old 06-28-2002, 10:56 AM   #7 (permalink)
Nut Hugger Bandwagon
Feedback Score: 18 reviews
According to FSM you have to remove that plug on the when properly changing the fluid and bleeding the engine. Another thing when you bleed the air out make sure you do it right because who evere did swap didn't properly bleed the engine and that casued my fans not to work.
Come to my HOOD talking that sh*t and I will bash your KNEECAPS EARLY!!!
RUTH'LESS 200sx is offline   Reply With Quote
Old 06-28-2002, 11:20 AM   #8 (permalink)
eric96ser's Avatar
The plug on the block is the drain for the block. Yes, you do have to remove that bolt when you change the fluid, but not to bleed it.
Old 06-28-2002, 02:13 PM   #9 (permalink)
the bleeders are on the thermostat housing and heater line near the firewall.
shoe is offline   Reply With Quote
Old 06-29-2002, 02:33 AM   #10 (permalink)
thanx to all of you...i really need to get a FSM but the Nissan dealer here (thailand) wont sell me one because they say it is copyrighted...i know they're lying....where did all of you u get your ?
Old 06-29-2002, 07:50 AM   #11 (permalink)
70/30 Racing
martin_g34's Avatar
Feedback Score: 36 reviews
E-bay
99 SE-L: boost coming soon
92/93 SE-R: VE daily pimpage
91 SE-R: 24 Hours of Lemons #75
92 G20: PTD #73 CLICK
martin_g34 is offline   Reply With Quote
