air bleed plug(s)? - SR20 Forum
Old 10-28-2003, 04:20 PM   #1 (permalink)
air bleed plug(s)?
can anyone tell me where the air bleed plug(s) for the cooling system are on the sr20de models?
i bought a haynes manual, but it seems to focus mainly on the ga16de.
kristen
Kristenthemum is offline   Reply With Quote
Old 10-28-2003, 04:34 PM   #2 (permalink)
Small nipple on the firewall, it's an appendage off the heater core hoses. Attach a hose to it, route it into the overflow tank. Why are you asking?
Old 10-28-2003, 05:30 PM   #3 (permalink)
Feedback Score: 4 reviews
Isnt there one on or near the thermostat too?
Old 10-28-2003, 05:37 PM   #4 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
The B14 only had the one on the thermostat housing, at the 1:00 position.
The community is here.
Old 10-28-2003, 05:51 PM   #5 (permalink)
VIVA MEXICO CABRONES!
Feedback Score: 20 reviews
Searching is very useful..........
http://www.se-r.net/zotz/se-r_coolant_change.htm
Sato
1 bar loop mod.. 15PSI power!
WE ARE A COMMUNITY!!!
SOMOS UNA GRAN COMUNIDAD!!!
GSRMx is offline   Reply With Quote
Old 10-28-2003, 06:00 PM   #6 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
There is also one on the front of the block, but in my opinion that one is a waste of time. WHen you fill the coolant leave the bolt out of the thermostat. Fill till coolant comes out of there. Then continue filling till coolant comes out of the nipple on the firewall. Then you shouldn't have any problems. Obviously run the car and contiue to add fluid till the reservoir is to the appropriate level and coolant is to the neck in the radiator.
Brent
1999 SE-L -- back to NA form
Old 10-28-2003, 07:03 PM   #7 (permalink)
I'm wanting to know because I need to change my coolant.
I looked for the one on the firewall, but couldn't find any? I found out from a website that the 92 SE-Rs had this bleed valve, but are you sure my 99 sentra has one? The book only tells of the one on the thermostat housing.
Old 10-28-2003, 07:08 PM   #8 (permalink)
GSRMx: Guess what? Some things change from year to year and model to model. I had already seen that page and looked for the valve near the firewall. I couldn't find it or any info about the 99 sentra, so I posted here. Searching wasn't very useful in my case.
Old 10-28-2003, 07:23 PM   #9 (permalink)
yes I know, and there are a *lot* of posts about this thing. The upper cap is gone from models 94 and up.
Old 10-28-2003, 08:06 PM   #10 (permalink)
thanks
Old 10-28-2003, 08:22 PM   #11 (permalink)
http://www.sr20forum.com/showthread....oolant+bleeder
here is a link that might be helpful.
