so then this is what i need....i have a p11 auto.....im just now pondering the swap
Parts list
Spec V tranny 02-06
Spec V axles
Spec V spindles if you have a B13 or B14, Not needed for B15, P10 or P11
SpeC V shifter and shifter cable
Spec V master cylinder, not need for P11 (i need since in a auto right now?)
Spec V Hydralic line, not need for P11(i need since in a auto right now?)
Spec V clutch pedal, not needed for P11(i need since in a auto right now?)
Spec V tranny mount driverside, need to make proper mount on B13, B14 and P10 (have to be fabricated?)
Spec V rear tranny mount, need to make proper mount on B13, B14 and P10 (have to be fabricated?)
Spec V rear Tranny mount bracket, need to make proper mount bracket on B13, B14 and P10 (have to be fabricated?)
Every 6 spd swap will need these parts no matter what, se-r, P10, P11, b14, whatever. they all need these listed.
Trans
Bellhousing from Greg V
Axle bracket from Greg V
Spec V axles
Spec V shifter and cables
S15 or JWT flywheel,
240 or 250mm clutch assembly.
Rear and pass mounts
you guys with P11 M/T cars do not need a clutch pedal assembly or lines because you already have a hydro setup.
i under stand that.....but like i said i have a auto........i wanna swap in the 6sp so i will need more than what is listed (the parts list that was listed is for if the car is already a manual, mines is not..) now the bellhouusing & axel braket are custom froma guy named Greg V??? or was that a typo??.......im not on this forum to much im more on the g20.net....so i was just wondering ................DRE.....if u can (i know its a pain) but u tihnk u coldu give me a complete parts list for the swap ??? rember *** i have a auto now so can u incdlude like ex. shift linkage's, manual ecu & what not
I believe that is for the 2000+ P11 M/T cars as the 1999 P11 is cable. Just to be clear and maybe help someone out.
all P11's are hyd trans. even the 1999. that was the changeover from cable.
If you have an auto, you will need the clutch pedal and bracket, lines, and master cyl as well.
There will be some fabrication involved as well. If you can not fabricate trans mounting brackets then thats not good. there are no direct bolt in trans mount brackets for this swap.
Go back and re-read the whole thread, post by post. there is so much info in this thread its unreal.
Im willing to do this, but it will have to be in 2007.
After my new paintjob,bodywork,suspension(coils,FST,Swaybars),r ims,cams, portwork, i think ill wait till 2007 to get the tranny in. I think by then, ill be bood to go.
"There is one thing man should truly fear...it is the INDIFFERENCE of good men..."
My Set Up:
Motec Exhaust*Walbro Header*MSD Rims*Jim Wolf Custom Paintjob*Injen Tires*Mugen Glove Compartment*MazdaSpeed Bridgeport*Edlebrock Exhaust Bearings*Calum Power Mirrors.
Damn My Sentra Hauls!!! 93 Whp of PAIN!!!
A good friend of mine Brian Karwan www.karcepts.com was one of the original fabricators of parts for the K20 honda swaps into civics. I am going to involve him in diagraming up some brackets and see if his company can produce a run of the mounts needed. Visit his website, his workmanship and technical engineering is beyond reproach. If he is interested in doing this, I'll let everyone know.
George Perinis Salvation is not found in a religion...it's found in a person, Jesus Christ, our Lord and Savior.
ok so if i have a p11 would i use these instead of the stock mounts? cause it says for the b13,b14, and p10 you need to make proper mounts and brackets... so i assume they bolt right into a p11.... i checked through the thread and havent seen the answer for this...
What exactly is the reason you must convert the front Spec-V hubs to 4x100? Just to match the wheels we have now? I'm thinking about doing this in the future and my wheels are universal 4-lug.
i believe he was asking why must you convert the 4x114.3 knuckle of the b15 to 4x100mm bolt pattern . . . . in which case so you would have the same bolt pattern front and rear and not mixed matched. however if you have a universal 4 bolt wheel, there really is no need to get them redrilled if you dont want too.
__________________ 2001 Sentra SE w/pp 5spd (white) 1992 Sentra SE-R 5spd (maroon) 1996 Grand Cherokee Limited v8 4x4 auto (chargold) 1990 Chevy K1500 4x4 5spd (beige) *Sold* 1993 Sentra SE-R auto (white) *Totalled 5-8-05* 1991 Accord EX dohc 4dr 5spd (white) *Totalled 12-20-03*
Right, this is what i was asking. Not "why you must use the spec-v hubs".
I was just referring to the bolt pattern issue basically.
