Old 06-21-2004, 05:49 PM   #1 (permalink)
sr20boston
1998ccs of fury
Trader Rating: 15 (100%)
HOW TO: Replace your clutch cable
* Remove battery
* Unbolt fuse box from battery pan
* Remove battery pan
* Disconnect top half of air box from hose(s) & remove
* Remove lower half of air box
* Remove resonator (?) (now exposed, next to air box)
* Loosen & disconnect cable from transmission end
* Optionally, remove driver's seat to give more working room
* Push cable toward firewall
* Laying on back beneath dash, disconnect end of cable from pedal
* Pull cable through firewall. Cable is between the brake booster and fender, far right side of firewall while facing it
* Disconnect cable from bracket beneath resonator - simply pulls out toward firewall
* Remove cable from bracket near brake booster, remove from car
* Install new cable in reverse order - adjust freeplay
* Reinstall other components
Not all the removal of stuff is absolutely necessary, but it makes the process easier. No pictures for this, unfortunately.
Also, getting to the point where the clutch cable attaches to the pedal is very difficult. You need a flashlight to see up into the area. You need small hands, or a helper with small hands, to reach up to disconnect/connect the cable. One should get familiar with the region (feel how stuff is connected) before doing the work.
Source: Jim Wright/Larry Weeks
Old 08-25-2004, 06:30 PM   #2 (permalink)
goneturbo
SE-R Searcher
Re: HOW TO: Replace your clutch cable
I stick a coat hanger or wire from the cabin through the clutch cable hole and attach the pedal harware for the new clutch cable to the other end. Then you can pull the new cable into the cabin much easier than trying to stick you big hand in the little space that is available within the engine bay.
95-200sx SE-R - Daily Driver, Injen CAI, S3 cams, Swisher F-STB, AGX's w/ Sportlines, SSAutoRust Header, Clutchnet Type 1PP, Kevlar-carbon kit & Flywheel
goneturbo is offline   Reply With Quote
Old 08-26-2004, 12:57 PM   #3 (permalink)
Nitelife
Nitelife's Avatar
This is for my NX, not sure if there is a clearance issue with the SER's.
Also, if you have cruise control, the module is right above where the clutch cable bracket attaches to the firewall. I had to remove the cruise module to gain access to one of the bolts attaching said bracket to the firewall.
To remove that module, I had to:
Remove the driver side wheel and pull back the wheel well lining.
There are two 12mm (IIRC) nuts holding the cruise module on under the lining.
With the module out of the way you can access the cable bracket.
Old 05-11-2005, 05:03 PM   #4 (permalink)
akapaul
Owned by Maximas!
No need to yank out the cruise control module and also no need to remove the bolts attaching the above bracket to the firewall. Simply yank the cable out of the firewall by wiggling it left and right. Very simple.
PK
akapaul is offline   Reply With Quote
Old 07-11-2005, 03:17 PM   #5 (permalink)
nssnskyline2
SE-R
How will I know when my clutch cable needs replaced.
I am in the learning process.
96 200sx SE-R--SOLD
nssnskyline2 is offline   Reply With Quote
Old 07-11-2005, 03:41 PM   #6 (permalink)
classicaddict
this foreum= FAIL
^ it will become stiff. or even snap.
i just replaced mine, i lubed it with silicone and it was awsome! now its back to being stiff what type of lube should i have used? would normal penitrating oil work? i think i only got lube in the rubber boot area and it didnt seep into the accual cable housing.
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 02-22-2006, 01:19 PM   #7 (permalink)
Hammerin Hank
Leggo of my eggo.....
Preventative maintenance: http://www.sr20forum.com/showthread....ht=brake+cable
Hammerin Hank is offline   Reply With Quote
Old 01-09-2008, 01:40 PM   #8 (permalink)
SE-R TUNED
se-r with attitude
What if the clutch is adjusted all the way and u still have play in the pedal?
Are there different size brackets or are they all the same? What about for the g20's?
1994 infinity G20 daily driver for now..... VE+T comin soon
1991 sentra SE-R in boost mode...7psi hold on to ur skin
1992 sentra xe R.I.P
Team N.V. Got an R?
Traffik Blockin NYC.org
Don't hate..,just NV
SE-R TUNED is offline   Reply With Quote
Old 01-09-2008, 02:46 PM   #9 (permalink)
1gDSMer
Rotten Egg
my nx cc was a PITA! i hate em. couldnt get my big ass arm up behind the clutch pedal..
matt
93 Electric Blue NX2000
1gDSMer is offline   Reply With Quote
