With both tranny's out of the car, the single roll pin can be knocked out, and the back of the yoke grinded flat and then swapped in 5-10 minutes.... and as was previously stated all thats needed for removal/installation is a hammer and a punch... Thanx
..Stack
Ok, I am a little confused. I have a question concerning a Classic SE-R. My friend sourced a 99 G20 tranny which is an open diff. He wants to know if he as to change the driver's side axle (I know going from an open diff to VLSD tranny that the driver's side alxe is different). So what axle could he use?
96 G20 Turbo:Sold
93 NX2000: daily beater
91 SE-R: SOLD
95 Miata: new toy
Jam, '99 P11 transmissions are the same model that came in earlier cars. You need a '00+ transmission for any of this information to be applicable. If his SE-R has an LSD transmission, then you need a non-LSD B13 axle. If his SE-R had an open diff, you can reuse the stock axle with that '99 transmission.
I just got my 2000 P11 tranny put in and here is what I think about it. I love the longer gears in 1st and 2nd, they go really well with the turbo engine. At first I switched the shift yokes to avoid grinding and I DIDN'T like the feel of the shifter at all. It moved the shifter way back at a horrible angle. I have a fully adjustable ebay shifter so I fixed that problem but the throws were just too strange for me. Instead of up and down shifts (l l l) they were at an angle like this (\\\). So I switch back to the P11 shift yoke and went to town with the angle grinder. Much better that way IMO. I still need to hook up the neutral and reverse switchs but that isn't going to be a big problem. All in said and done I am happy with how everything turned out.
nonLSD axles from B13 fits non LSD B15/P11 on B13
nonLSD axles from B14 fits nonLSD B15/P11 on B14
and so on......
that should be easier its pretty common sense!! the LSD unit ina B15/P11 is EXACT to those LSD units in B13/B14 trannies---thats why you use the same Phantom Grip on them (#906).
so if you get a non LSD B15 trans then youll need non LSD axles from whatever chassis your installing onto....
If I buy a 00+ B15 limited slip tranny it is the same as a 00+ P11 tranny except for the gear ratios?
Whoa, wait a minute. I have been watching this thread since the first week. There is a difference in gear ratios between the B15 and P11? What are they if so? I searched through this thread from the beginning and didn't see anything. (Maybe I overlooked it)
I think the 1st and 2nd gears of the B15 (00+) and B14 trannies and the final gear ratios.
The difference between the B15 (00+) and the P11 (00+) trannies is final ratio and the fifth gears.
At least that is what I gathered from the very first page of this thread on the gear ratio chart halfway down the thread.
I don't know how to add pictures so you will just have to go back to the first page and let all the pictures load if you want to view it and see the exact gear ratios and numbers, sorry.
Try page one. Towards the bottom of the page NissanSpeed01 posted some Excel spreadsheets with the different gear ratios.
Yeah well I saw red X's when I went back yesterday before I posted. This morning I copied and pasted the links in my browser one at a time and then went back and they all showed in the thread from being cached. Wierd. Thanks and now after finding a B15 tranny for a good deal I'm depressed.
Those gears are SHORTER not longer dude.
Do you really, really, really need full boost in second gear? This came up on the SE-R list a few years ago concerning lighter flywheels. The concensus was that they really didn't impact actual driving performance.
And the gear ratios changed a bit from year to year and from model to model in the final drive. You just have to do a lot of digging and do the math for yourself when it comes to final drive; the FSMs display a lot of Nissan Math that just doesn't jive.
-=|JP|=-
