Old 10-31-2005, 12:25 PM   #241 (permalink)
nismoboy
question, what box would be best suited for converting a pulsar gtir to front wheel drive (2wd) ?? thanks
nismoboy is offline   Reply With Quote
Old 10-31-2005, 02:37 PM   #242 (permalink)
CowboyDren
Simian Rex
RS5F70V...if you can get one. As stated before, I'd rather use the gear stacks and differential ring and pinion from a 1.8l Sentra (RS5F70A), if they'd fit inside the V case and work with the viscous coupler.
CowboyDren is offline   Reply With Quote
Old 11-17-2005, 05:25 AM   #243 (permalink)
4x4
i just got in my tarny from the u.s
will the clutch fit on both tranys ? or i need to change it ?
4x4 is offline   Reply With Quote
Old 11-21-2005, 03:59 PM   #244 (permalink)
CowboyDren
Simian Rex
The clutch should be 100% interchangable.
Old 11-22-2005, 02:27 AM   #245 (permalink)
hpro123
SE-R GREEK
So, would the RS5F70A from the 1.8 liter engine be "equivalent" to the plain old RS5F32A I have in my car right now?
Strong as the RS5F70V but with open diff?
Old 11-22-2005, 09:50 AM   #246 (permalink)
GregV
Approved vendor
Trader Rating: 87 (100%)
The trick thing to do here is buy the Nismo dif for the Non LSD cars for around $1000 (From me of course) and then buy those 1.8 tranny for a dime a dozen. Yes, they should be as strong, and have the better gear ratios. Then if you blow them up, go buy another cheapo 1.8 and swap the dif and keep going.
Greg V
RIP John and Danilo
Old 11-22-2005, 10:04 AM   #247 (permalink)
VVLtrain
Mmmm gas smell..
So by doing this would you need to use different axles also? Or can you use the standard LSD equipped car axles on the non LSD 1.8 tranny with nismo dif in it?
-L
VVL
'94 SE-R w/ VE
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 11-22-2005, 10:11 AM   #248 (permalink)
Spec-V-n-NyC
Pimpin Aint EZ'
When I did my B15 swap I had to use a 98 SE or 99 SE-R Driver's side axle to get it to fit my b13.
-B
91 SE-R Gti-R swap [PARTED OUT]...99' Infiniti G20T
Spec-V-n-NyC is offline   Reply With Quote
Old 11-22-2005, 10:20 AM   #249 (permalink)
GregV
Approved vendor
-L
You would use the LH axle from a non LSD like a 98-99 B14. Nismo makes a dif for cars with LSD and a different one for w/o LSD. The w./o just happens to be alot more expensive. But if you factor in the price of trannies and what you would pay for a Nismo dif anyway, and with the better gear raios, it makes alot of sense.
Old 11-22-2005, 10:21 AM   #250 (permalink)
GregV
Approved vendor
because you used a non LSD tranny. sh*t, I need to edit my message above now. You're right.
Old 11-22-2005, 12:26 PM   #251 (permalink)
hpro123
SE-R GREEK
I see you managed to edit the post with the $$ for the Nismo lsd! I was just about to take you up on it!! (the original number... dime a dozen indeed!! )
Old 11-22-2005, 04:39 PM   #252 (permalink)
VVLtrain
Mmmm gas smell..
Thanks for the clarification Greg. BTW that avatar is SCARY. I will make sure I keep my drinking down to a minimum at the convention if you are around.
-L
Old 11-22-2005, 04:45 PM   #253 (permalink)
GregV
Approved vendor
-L
I was told that was your high school picture?
Old 11-22-2005, 04:52 PM   #254 (permalink)
VVLtrain
Mmmm gas smell..
I don't have blonde hair nor use that shade of red cheek color.
Old 12-21-2005, 11:11 AM   #255 (permalink)
Doug_O
Big Bossman
Doug_O's Avatar
Just wanted to add this here. This is some data that I collected when trying to hunt down a B15 trans with LSD
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 12-21-2005, 03:55 PM   #256 (permalink)
junknstuff
nx-less
Trader Rating: 15 (100%)
so...i'd be looking for a vin that is somewhere around 3N1BB51D*YL****** correct?
something along the lines of YL=YesLSD maybe? (not to be accurate of course...)
- jason
damn you eKool
junknstuff is offline   Reply With Quote
Old 12-21-2005, 11:04 PM   #257 (permalink)
Doug_O
Big Bossman
Doug_O's Avatar
I would at least start with getting the VIN from the tranny you're interested in. Then compare it to the ones I have listed above. If it follows the 3N1BB51D**L, go give it a look.
Doug
Old 12-26-2005, 11:53 PM   #258 (permalink)
coalitionSE-L
Grandma's gonna get ya!
coalitionSE-L's Avatar
Originally Posted by Projnx2000
Thanks Jonathon for starting this thread.
I wanted to add something I found while converting my P11 to cable. On my specific tranny (2002 G20, locking) there is a insert where the clutch arm rests in
comparing to a B13
Some quick measurements on the lip above the insert show that without the insert the mounting/pivot hole for the arm is the same diameter as my B13 tranny. So maybe grinding of the B13 shaft might not be needed, only removal of the insert.
After removal of the insert, the grinding of the B13 arm is NOT needed.
Does anyone know of a good way to get the insert mentioned above out? Advice would be GREATLY appreciated. TIA
1999 SE-L SR20DET-- Sold!
Old 12-28-2005, 08:14 PM   #259 (permalink)
Killdannow
this thread is way too long, please edit it down.
From what im reading, the 1.8 tranny would install just like the p11/b15 tranny - well it is a b15 tranny. But Im still confused and my eyes hurt from reading page after page. Is it just cheaper, or possibly easier as well?
Clean a$$ hell red 200sx.
Old 12-28-2005, 08:41 PM   #260 (permalink</
