Old 02-07-2006, 01:44 AM   #281 (permalink)
BookDet
Originally Posted by nxsnx
yes its been done
andwhat are u the parts needed
92 B13 se-r
96 B14 se-r
BookDet is offline   Reply With Quote
Old 02-07-2006, 04:53 AM   #282 (permalink)
Slow 96R
GTIRoids
Trader Rating: 62 (100%)
Originally Posted by BookDet
One question as anyone finished the b15 6 speed swap yet?
Very costly based on the conversation I had with the guy in the Big Apple that did it. If I'm not mistaken it was in the $2k range when completed
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 02-08-2006, 08:39 PM   #283 (permalink)
93specv
i learn as i go
Originally Posted by myprojectB13
B13 Axles
The write up lists absolutely everything you need.
so you do or dont need the p11 axles? the writeup says nothing about axles.
BOOST!!!!! coming soon '08
All Your Local Repair and Custom Needs:
Anthony Q
A&C Imports LLC
(603) 669-2824
e-mail: ant280@aol.com
Old 02-08-2006, 10:40 PM   #284 (permalink)
98SE(-R)
here we go again....
read the rest of the thread!
you won't have to change your passenger axle/halfshaft no matter what (provided you got a SR20)
driver axle depends on what tranny you are putting in and chassis you have:
installing a lsd tranny?: use a lsd tranny axle for your chassis:
i.e. for people with B13 and 95-97 B14 se-rs, use your current axles, for people with 98-99 SE-R/SE/SE-Ls, go get a 95-97 SE-R axle
installing a non-lsd tranny?: use a 98/99 SR20 equipped car axle for B13 and B14s
use a B15 SE w/o power package axle for B15s
use a P10 w/o lsd axle for P10s
Got it? Punk!!?!?!
JWT flywheel $300 obo
http://sr20forum.com/showthread.php?t=179181
clutch cable $40 and pedal $30 obo
http://sr20forum.com/showthread.php?t=179177
Clutch slave cylinder $40 obo
http://www.sr20forum.com/showthread.php?p=1751541
98 200sx OE pass headlight $40 obo
http://www.sr20forum.com/cosmetic-mo...eadlights.html
98SE(-R) is offline   Reply With Quote
Old 02-08-2006, 11:37 PM   #285 (permalink)
BRE92SER
SE-R Geek / Nissan Tech
lol....i know this thread is long, but I've read it, and you should too, before asking....EVERYTHING is covered, you just gotta read. print it out and read it that way, makes it a bit easier.
USE THIS FIRST!!!
V
http://www.sr20forum.com/search.php
Old 02-08-2006, 11:57 PM   #286 (permalink)
98SE(-R)
Ah! I found one thing that is not covered! I tried emailing gregv but I think I have his old email and it never got to him (from when he was at mossy, before he moved to *edited to protect the innocent*, and then back to mossy)
that, or he's too busy (yeah right!)
anyway....here's the Q
NISMO limited slip? to fit or not to fit?
will one fit in a P11 non-lsd?
will one fit in a lsd tranny?
it does not say it WON'T fit there!
BUT it doesn't say it fits...
in a P11 ANYWHERE!
sorry, it's getting late for me, and I got Dr Suess on the brain :crazy:
So, does anyone have the answer?
perhaps we can compare the part numbers for the RS5F70 and RS5F50 stock vlsds to find out.
Old 02-09-2006, 12:05 AM   #287 (permalink)
BRE92SER
IIRC, there are 2 versions, 1 for a LSD trans, and one for non-lsd stock. both retail for around $1000. get the one for the trans you have
Old 02-09-2006, 12:58 AM   #288 (permalink)
98SE(-R)
but do either fit the RS5F70 transmissions? that is the question. I heard someone on this board say once that Nismo does not make a limited slip for the B15 trannies, but it has never been officially (and by that I mean by someone that has tried it) confirmed or denied.
Also, the OEM lsd one is about $700. that's a pretty big difference from the $1075 for the non-lsd unit listed on mossy performance. but its offset by the lower cost of the non-lsd tranny by a little.
Never seen a writeup on one of these nismo lsd installs either: any shimming required for these front drive lsds? I know it is needed on the rear dirivers to adjust axle bias and breakaway torque.
Seeing how the breakaway torque is "pre set" at 36 ft-lb, I would guess not, but doesn't hurt to ask.
EDIT:
I just got a email from greg. Thanks alot man!
To: parts@mossyperformance.com
Subject: NISMO lsd for P11 G20s
do the limited slips that are listed on your site fit 5 speed 2001 and
2002
G20s (transmission RS5F70A or V)?
http://www.mossyperformance.com/product/?id=4077
http://www.mossyperformance.com/product/?id=5098
I can't get any confirmation from anywhere that they do, and your
application list is a bit ambiguous.
also, is the unit a straight drop in or does it need to be shimmed and
adjusted?
is a housing gasket provided in the install kit also or does
the transmission just use the grey RTV for that seal?
Thanks for your time
Rhett Rushton
98SE(-R) on sr20forum.com
REPLY:
In order of your questions:
Yes they fit. Order the correct one. w/ or w/o OEM LSD
Straight drop in sort of, you may still need to check clearances, but
that's normal.
Silicone.
Thanks,
Greg V
Old 02-09-2006, 11:11 PM   #289 (permalink)
BRE92SER
RS5F70[A] or [V]???--im not sure, I will check tomorow if i remember, though.
I think the all lsd [V code] ring gears are the same size, and all non lsd [A-code] ring gears are the same, IIRC. so my guess is that if it fits one, it fits the other.
also, i dont recall that they need to be shimmed. its not noted in the catalog, and usually stuff like that is. also, since it lists its breakaway torque, I would guess that it wouldnt need to be preload/bias adjusted. Not 100% though.
Old 02-10-2006, 09:49 AM   #290 (permalink)
GregV
Approved vendor
Trader Rating: 87 (100%)
{A} is the open dif, {V} is the viscous (LSD)
When I say shimmed, I mean there are shims in there on the outside of the bearings. If you pick fly sh*t out of pepper, you can check all the clearances and stuff and adjust as necessary. If you're like me, you bolt that focker in there, and have the tires spinning before the jack is down.
Greg V
RIP John and Danilo
Old 02-10-2006, 10:01 AM   #291 (permalink)
BORNGEARHEAD
Gone!!!
Trader Rating: 24 (100%)
Of the 15 pages, I'm not sure if this has been noted. Nissans designation for transmissions goes like this:
RS5F70[A]
RS=Remote Shift--------FS=Fixed Shift
5=5 forward gears-------6=Forward gears
F= Front drive-------------R=Rear wheel drive
70=Model designation
A=Standard/open final drive------V=ViscousLSD------H=Helical
*Obama for 2008*
BORNGEARHEAD is offline   Reply With Quote
Old 02-25-2006, 07:43 PM   #292 (permalink)
RedDragun
The DET is in!
Trader Rating: 17 (100%)
Wow, just got done reading all of this and this is what I took from it.
I want the 2000+ P11 Tranny.
I am coming from a 1.6 B13, so I wan't 91-94 SE-R axles, or 95-97 LSD axles, correct?
The clutch for an SE-R tranny will fit the P11.
I want the P11 over the B15 tranny because I will have turbo (more powah).
All seem right?
RedDragun is offline   Reply With Quote
Old 02-25-2006, 09:02 PM   #293 (permalink)
98SE(-R)
yup, you got it. and the nismo lsds fit too!
Old 02-27-2006, 10:48 AM   #294 (permalink)
Mr Sentra
Keeping It Real
I wish someone would actually try the Nismo LSD in a B15 with LSD to actually positively know that it will fit. Noone's done it. Someone should be the pioneer.
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 02-27-2006, 11:06 AM   #295 (permalink)
Isfahan
El Rey de los Chingones
Isfahan's Avatar
Check here:
http://www.sr20forum.com/showthread.php?t=146753
WE are a community
Isfahan is offline   Reply With Quote
Old 02-27-2006, 11:30 AM   #296 (permalink)
Mr Sentra
Keeping It Real
Originally Posted by Isfahan
Super! Thanks for the link.
Old 02-27-2006, 12:21 PM   #297 (permalink)
NX$paniard
easy 400WHP
Trader Rating: 26 (100%)
Theres nothing to try. I have fit a B13 LSD into the B15/P11 case. It is the same.
I guess I cant say Im 100% sure cause I didnt sit there and count teeth, but it will fit.
~jRod
Old 02-27-2006, 12:25 PM   #298 (permalink)
McCoy I am a moderator
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 72 (100%)
GregV has put the Nismo lsd into the B15 tranny, so it is 100%. This is good... so now when I strip 3rd gear on the track, I just have to find a B15 parked somewhere to borrow there tranny
I was always under the assumption that it wouldn't work... probably due to the nissan parts guy (not Greg) that I talked to about this when purchasing my nismo lsd.
Old 02-27-2006, 01:05 PM   #299 (permalink)
GregV
Approved vendor
