Old 02-27-2006, 04:33 PM   #301 (permalink)
Mr Sentra
Keeping It Real
I'm a believer!
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 03-03-2006, 10:18 PM   #302 (permalink)
javierb14
3.0 bar MAP
So who has switched to hydro in a b13? I threw a S13 pedal assembly/MC on my b13 and it basically bolts up. You have to trim the lip on the firewall, possibly fab up a little reservoir, and triangulate the pedal assembly...but it looks as if it would work.
Does anyone have pics of a G20 pedal assembly on a B13? I'd like to see the pedal placement.
www.full-race.com
javierb14 is offline   Reply With Quote
Old 03-06-2006, 12:42 AM   #303 (permalink)
98SE(-R)
someone should check the part numbers for B13,14, P10 and compare to P11. the firewall hole and even the entire pedal assy looks the same as mine.
JWT flywheel $300 obo
http://sr20forum.com/showthread.php?t=179181
clutch cable $40 and pedal $30 obo
http://sr20forum.com/showthread.php?t=179177
Clutch slave cylinder $40 obo
http://www.sr20forum.com/showthread.php?p=1751541
98 200sx OE pass headlight $40 obo
http://www.sr20forum.com/cosmetic-mo...eadlights.html
98SE(-R) is offline   Reply With Quote
Old 03-14-2006, 10:07 PM   #304 (permalink)
nissan se-r
GT28RS
Anyone found out where to get these switches? I have a P11 coming in soon.
Originally Posted by NX$paniard
switches are for lights only.. the black one is for your reverse lights
the blue one is for neutral..
i wish I knew where to source those connectors. i only need one more and have no idea where to find them..
This is all u need..
nissan se-r is offline   Reply With Quote
Old 03-14-2006, 10:14 PM   #305 (permalink)
sr20boston
1998ccs of fury
Trader Rating: 15 (100%)
The new tranny should come with the switches from the P11. It's just 4 wires (2 wires per switch), just cut the P11 connector off and wire it into the B13 harness.
Old 03-14-2006, 10:37 PM   #306 (permalink)
NX$paniard
easy 400WHP
Trader Rating: 26 (100%)
thats assuming the connectors come with it. The switches themselves can be purchased through GregV @ Mossy Nissan.
The connectors I still havent found out where to get them. I still need onemore. Currently I have my revcerse lights hooked up, the neutral is not connected right now..
~jRod
Old 03-15-2006, 10:12 AM   #307 (permalink)
GregV
Approved vendor
Trader Rating: 87 (100%)
You know, I need these too. I'm pulling the tranny out again because the clutch collapsed. I'll take some photos and put them up.
Greg V
RIP John and Danilo
Old 03-17-2006, 10:21 AM   #308 (permalink)
sr20boston
1998ccs of fury
So when you buy the switches, they don't come with a pigtail and a connector on the end? What connector do you mean?
Old 03-17-2006, 10:45 AM   #309 (permalink)
NX$paniard
easy 400WHP
correct, sir. When you buy the switch its just the switch in a little Nissan Baggy.
I guess Nissan assumes youre buying it for the correct car so you wont need a connector to splice
Ive never had luck trying to order JUST a connector from Nissan. Most connectors on a B13/B14 you can find on other Nissan cars, but this one is pretty weird. I havent found it on anything in the junk yards. I wonder if we could find an aftermarket automotive connector/harness manufacturer and just have them make a sh*tload of them, as this will be a pretty popular swap (b15/P11 trans).
Know of any?
Old 03-21-2006, 09:35 AM   #310 (permalink)
GregV
Approved vendor
My impressions of driving my B13 w/B15 trans
To preface my commemnts, I have a B13 w/Bluebird motor and GT28RS Disco Potato, running about 14 psi and around 330WHP give or take. I just got the tranny in and have driven it maybe a week. I don't have any data regarding the strength. Maybe as time goes by.
So... damn my car is fast! The tranny gearing definitely feels short. I have a 45 mile commute and usually drive 85+, and at 85 it's turning around 4,000 RPM. Now alot of noises go away around 4k, but alot of sh*t gets louder too. The gearing is really high here. The upside is any speed above say 70, you goose the accelerator without downshifting, and the car builds max boost in a second, and you're going whereever you;re pointed. Unless you really need to get on it there is no reason to downshift. This car will is a freeway killer up to redline (about 160 mph), but who would drive that fast anyway .
1st and second are really low. I'm going to have to call Greg Perry and Rockwood, and learn how to drag start with a turbo car. I think short shifting it just past 40 mph, get it into third and friggin lay on it! I need one of those trick-ass boost controllers.
But all in all, it feels definitely short all over. Maybe because I spend so much time on the freeway?
Anyone wanna trade for a P11?
Old 03-25-2006, 02:57 PM   #311 (permalink)
coryb13ser
the proof wizard
well it turns out i bought that se-l axle for no reason, they gave me a locking b15 trans for 400 bucks
but i would really like to see some pics of the grinding to the stabalizer... or maybe a little more description. thanx
12sec NA
Old 04-07-2006, 02:33 PM   #312 (permalink)
NJse-r
woo dee woo
I just got a B15 transmission. I need a little info about the wires coming from the tranny. I know the one is for the reverse lights but the other one is for the neutral switch? I have a 1994 B13 and no light comes on when the car is in neutral (on the dash I am assuming), what does the neutral switch do?
NJse-r is offline   Reply With Quote
Old 04-07-2006, 03:02 PM   #313 (permalink)
JohnnyFriend
Speed Junkie
I have a b15 in my 94 also I didn't hook up that switch haven't had a problem
94 SE-R Avenir de-t w/gti-r ecu, JWT S4's,
pressure plate,&stage 1 clutch, Fidenza
flywheel,B15 transmission,444cc injectors,
avenir maf,nismo fpr,Turbo xs boost controle,
Greddy BOV,MSD 6A-----SOLD
JohnnyFriend is offline   Reply With Quote
Old 04-07-2006, 03:10 PM   #314 (permalink)
VVLtrain
Mmmm gas smell..
I thought that is the safety switch that you press down on the pedal to keep the car from starting in gear? If you dissabled this from inside the car, then you dont need it to be hooked up. AFAIK.
-Linus
VVL
'94 SE-R w/ VE
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 04-07-2006, 04:18 PM   #315 (permalink)
NJse-r
woo dee woo
Sweet....do you have any pics that show exactly how much material has to removed from the shifter stabilizer bracket. I would like to avoid the trial and error of grinding and installing/removing the trans if I could.
Old 04-07-2006, 05:14 PM   #316 (permalink)
VVLtrain
Mmmm gas smell..
http://www.sr20forum.com/showpost.ph...&postcount=167
This posted on this mega long thread LOL. I believe this picture is from a b14 but I think it should be the same.
It's funny that you are mentioning this because I am installing my B15 tranny in my '94 this weekend!!!
-L
Old 04-07-2006, 06:27 PM   #317 (permalink)
myprojectB13
myprojectB13's Avatar
Trader Rating: 16 (100%)
-L
Yeah right!
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 04-07-2006, 06:53 PM   #318 (permalink)
NJse-r
woo dee woo
-L
I started to install mine today. I machined my B13 arm and did some other stuff. Oh yea.....my 1994 B13 electric speedometer sensor went right into the B15 trans. The little plastic gear seemed to be identical in size to the gear on the B15 unit so I believe it should work fine.
Old 04-07-2006, 11:19 PM   #319 (permalink)
VVLtrain
Mmmm gas smell..
Originally Posted by myprojectB13
Yeah right!
