Old 04-30-2006, 11:03 PM   #321 (permalink)
Slow 96R
GTIRoids
Trader Rating: 62 (100%)
Originally Posted by RedDragun
So if I am ordering new Raxles, and I will be getting a B15/P11 open diff tranny, then I need to tell them I need axles that fit the 98-99 SE-R/SE-L manufactured after 10/97?
They are all interchangeable. Atleast they are with the diff trans axles. I just put a B14 axle in my boys B15. Just get axles for the open diff. Use whatever year your car is. $.02
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 05-01-2006, 02:04 AM   #322 (permalink)
coryb13ser
the proof wizard
Trader Rating: 26 (100%)
im loving my b15 tranny with vlsd, but i was wondering if anyone else has noticed having a hard time going into 3rd somtimes. never during nice, daily driving, but when your really going for it, and you hit 3rd gear hard. i never missed with my old tranny but now i find my self missing 3rd everyone now and then, i was wondering if its somthign to do with the linkage being a little different, or if it was just in my case.
12sec NA
Old 05-01-2006, 02:29 AM   #323 (permalink)
Spec-V-n-NyC
Pimpin Aint EZ'
I'm not missing it....it just grinds a little when I try to get it into 3rd quickly.
...still annoying ***, maybe a little thicker gear oil will help or some of that shockproof sh*t.
91 SE-R Gti-R swap [PARTED OUT]...99' Infiniti G20T
Spec-V-n-NyC is offline   Reply With Quote
Old 05-01-2006, 05:41 AM   #324 (permalink)
Yellow4g63
Enemy of the stupid
same here, I think it's that crap gear oil I bought at Autozone. I'm going to try some thicker stuff. btw I used 75-90w gear oil.
91 NX2000 The VE daily driver
http://www.drag240sx.com/
Old 05-01-2006, 06:51 AM   #325 (permalink)
Slow 96R
GTIRoids
Put the car in third gear, jack it up and go under there and verify that nothing is hitting. It may be where you had to grind it needs a little more off of it.
Old 05-01-2006, 08:13 AM   #326 (permalink)
RedDragun
The DET is in!
Trader Rating: 17 (100%)
B13 Sentra SE-R's never came with open diff tranny's....
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 05-01-2006, 02:02 PM   #327 (permalink)
Slow 96R
GTIRoids
I know, you will have to buy a axle for the drivers side in open diff form from a sentra SE with a 2.0L motor in it. I believe they are years 98-01. Double check the years on that. Also you may be able to use a axle from a G20 that had an open diff. Not sure of that either. Not sure anyone has tried this yet, so you'll have to be the lab rat
Old 05-02-2006, 01:06 PM   #328 (permalink)
coryb13ser
the proof wizard
nothing hits, it just doenst like to go into 3rd quickly. i guess thats what we'll have to live with...
Old 05-02-2006, 08:17 PM   #329 (permalink)
Slow 96R
GTIRoids
It could be the trans fluid. I know my Shock proof heavy (red) makes the shifting tougher. I think I'm gonna try Royal Purple this time around and see if it helps any.
Old 05-02-2006, 11:30 PM   #330 (permalink)
Yellow4g63
Enemy of the stupid
Slow 96 mine grinds sometimes too but I'm running the cheap stuff you get from the auto parts store. Maybe it's the Save a 3rd gear system nissan made. If you can't shift fast it will lasts longer lol.
Old 05-03-2006, 05:04 AM   #331 (permalink)
Slow 96R
GTIRoids
Oh I see, they idiot proofed it
Old 05-03-2006, 11:58 AM   #332 (permalink)
Ricer_X_01
15642uner
Ricer_X_01's Avatar
my tranny in my SE i bought new, has never grinded 3rd.
Ricer_X_01 is offline   Reply With Quote
Old 11-04-2006, 02:38 AM   #333 (permalink)
gixter22
LSD
What does LSD stand 4 in re/transmissions?
Hopefully it's Limited Slip Differential.
gixter22 is offline   Reply With Quote
Old 11-21-2006, 01:29 PM   #334 (permalink)
camarok
It pulled a premium :)
wow. I need to blink more often.... that was ALOT of reading.....
~KEVIN
The '98
Nissan 200SX SE-R - 122k
Red on Black
sr20forum.com?
sr20 - forum . com?
camarok is offline   Reply With Quote
Old 12-05-2006, 05:34 PM   #335 (permalink)
RBNMYZ
NISSAN GOD
how did you go about removing the roll pins ? and anyone have pics of the grinding for the shifter linkages
horse power is for braging rights torque wins races
RBNMYZ is offline   Reply With Quote
Old 12-06-2006, 08:03 PM   #336 (permalink)
98SE(-R)
here are the pics i took of my recent swap.. the first two are the sh*t rod, the third and fourth are the support rod. instead of having to take the trans out each time to get the fit right, i just disconnected the linkages. this requires you to jack up the engine and loosen the bolt ont he motor mount next to the stabilizer rod to get it out *** the bolt prevents the rod from coming out all the way.
anyway, I installed and pulled the linkages 10-12 times before i got them ground down enough. like coalition says, this is the hardest part. you have to grind a ton to get the two to clear each other
shift rod
and stabilizer bar
JWT flywheel $300 obo
http://sr20forum.com/showthread.php?t=179181
clutch cable $40 and pedal $30 obo
http://sr20forum.com/showthread.php?t=179177
Clutch slave cylinder $40 obo
http://www.sr20forum.com/showthread.php?p=1751541
98 200sx OE pass headlight $40 obo
http://www.sr20forum.com/cosmetic-mo...eadlights.html
98SE(-R) is offline   Reply With Quote
Old 12-06-2006, 08:08 PM   #337 (permalink)
98SE(-R)
you can see i even ground down the bolt on the shift rod. for reference the two sides of the clevis on the shift rod were the same dimension before grinding,
Id say i ground about 3/16" off the shift rod and a .25 inch step in the support link
I finally got my trans in and did a hydro clutch swap also
the thing shifts like butter and with a lsd i can get my car to rotate instead of nose dive. its like night and day
FYI the B15 trans is quite a bit heavier than the non lsd b14 trans
I'll be doing a writeup after the semester ends on the hydro clutch swap. its amazingly straightforward
EDIT
I'd like to thank Coalition SE-L and myprojectB13 for the writeups and Slow96R for the tips and Yahnozha on G20.net for his writeup on P11 auto to manual swap. some good pics there even *** i my swap was manual to manual
Old 12-07-2006, 10:15 AM   #338 (permalink)
Saaby
Living up Boost
Wow...this is what I love about this forum. Innovation. I have been enlightened. And what great timing for me. My clutch disk just exploded and I have the tranny off the car. This gave me the opportunity to actually gain something positive from this situation. I planned on putting a Nismo limited slip in my 99 tranny. Then I decided for that hefty price, I might be better off getting a 97 tranny and getting the much cheaper Nismo LSD for VLSD trannies. And then I found THIS thread.
Instead of a 97 tranny, hell just upgrade an LSD P11 tranny with a Nismo LSD and Driver Axle and throw them in. It looks very enticing, but the only thing holding me back is all the grinding. What I thought would be nice, is for someone to manufacture modified versions of the parts that need to be grinded, sort of a P11/B15 conversion kit! Anyone?
-saaby
Saaby is offline   Reply With Quote
Old 12-07-2006, 10:51 AM   #339 (permalink)
98SE(-R)
good luck finding a transmission, let alone one with LSD. it took me a month of online searching and phone calls. That was at the end of the race season ***.
it isn't that hard to grind. If you did all the other mods on your car, you can do this. its not so much as difficult as it is tedious.
Old 12-07-2006, 10:56 AM   #340 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
98SE(-R) What car is taht clutch pedal out of?? Maxima, B15, Altima? also, where do you put your resivour?
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
