HOW TO: P11/B15 transmission swap into a B13/B14/P10 - Page 2 - SR20 Forum
Old 12-07-2004, 02:38 PM   #21 (permalink)
Its Slow
Feedback Score: 6 reviews
Originally Posted by SE-Rawkus
I don't think those Excel figures are correct.
I know the stock gauges aren't too accurate....but it can't be off by almost 10 MPH.
In 5th gear @ 3K RPMs...my speed on my tach indicates 60 MPH
I think that they might be. With stock wheels with 205-50-15 tires, I see right around 70 @ 3krpms. His chart says 66mph. Stock gauges arent very accurate, as you said. Only way to tell 100% is to get a gps.
- Justin
http://www.imagestation.com/picture/...e/f9a9e41f.jpg
http://i149.photobucket.com/albums/s...rley05/b14.jpg
96 SE-R White, BIG turbo
96 SE-R Black, stock mostly
05 Dodge Ram 1500 4 door 4x4, Tow vehicle
Justin is offline   Reply With Quote
Old 12-08-2004, 08:44 PM   #22 (permalink)
Professor Dingbat
Feedback Score: 14 reviews
So you do not use the neutral switch or the reverse switch at all?
Old 12-23-2004, 04:22 PM   #23 (permalink)
Simian Rex
Just so y'all know, AutoZone sells a three-piece kit with the hex drives for the B15/P11 transmission drain and fill plugs; about $8.
As far as 72 MPH in second gear with a 7800 RPM redline; I've done that math before, and it's correct. B15s have pretty tall tires.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 12-24-2004, 05:38 PM   #24 (permalink)
Feedback Score: 4 reviews
this sounds pretty close to me... with the difference between all the different tire/wheel combinations that are being used... accuracy shouldnt be that big of a concern. the chart though isnt that far from being correct after doing the math... good job.
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 12-26-2004, 09:36 PM   #25 (permalink)
70/30 Racing
Rockwood's Avatar
i didnt know the earlier P10s had a longer final drive...
of course, that would explain why i had to swap out the output shaft diff gear to use P10 gears on my SE-R.
MotoIQ Project G20:
Old 12-27-2004, 02:02 AM   #26 (permalink)
myprojectB13's Avatar
Feedback Score: 17 reviews
I found this out the hard way when trying to put a 92 P10 gear stack into my SE-R trans using my SE-R LSD and final drive.
Jonathon
1996 G20
1993 SE-R 13.35@102
Old 12-27-2004, 02:17 AM   #27 (permalink)
myprojectb13, do you by chance still have the tranny mount for the P11?? If so, I would be interested in buying it since I am swapping a from auto to manual....let me know.
Mike
Az99G20t is offline   Reply With Quote
Old 12-27-2004, 09:58 AM   #28 (permalink)
Mike
Sorry, the mount didn't come with it.
Old 01-01-2005, 07:17 AM   #29 (permalink)
ya dig
Feedback Score: 11 reviews
i dont know...my friends civic stock 93 lx....46 in 1st 70 in 2nd 110 in 3rd
" I take three L's to the head, love , live , life then im dead"
P11
SE-? is offline   Reply With Quote
Old 01-11-2005, 12:17 PM   #30 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
So did anyone figure out how to deal with the reverse and neutral position sensors??
Old 01-11-2005, 05:42 PM   #31 (permalink)
'The Sleeper'
Does anyone know if the NISMO diff. will fit into this baby?
I bloody well hope so!
Cheers
Dave
N15 with a built SR20DE+T.
GT30R hybrid at 22 PSI...403 WHP (dyno' in 5th gear)
Bull GTi is offline   Reply With Quote
Old 01-11-2005, 10:51 PM   #32 (permalink)
SE-R Monster
the switches can be rewired all they are is a pos and neg wire (my way of explaining) so just hook em up i dont think it matters the colors to much. did in my b13 and the tranny nutral switch and backup switch work fine.
2k2 aztec red specv (i/h/e/p/mm)(sold)
92 classic with mods (dismantled)
94 classic rare blue (totaled rearend hit)
91 Black (whole lotta attitude )
My true loves
http://www.sr20forum.com/turbo/158047-my-sleeper-p.html
mr.sentra_specv is offline   Reply With Quote
Old 01-19-2005, 02:50 PM   #33 (permalink)
Simian Rex
Nobody's had the balls to try yet. Did the RS5F70 come in any non-US cars?
Old 01-19-2005, 02:59 PM   #34 (permalink)
Simian Rex
Originally Posted by Slow 96R
Just tell him to look at the seals. One should be much larger (2X) than the other. If they are the same size it's an open diff. Also he can look for the LSD hump as noticed in the above pic, but that's hard to tell unless you know what your looking for.
Which hump is that, Joel? Which picture?
Old 01-21-2005, 09:28 AM   #35 (permalink)
Godzilla
Do you have any extra pics of the install preferebly the grinding
of the tranny.
IN BOOST WE TRUST.
Specialist-V is offline   Reply With Quote
Old 01-21-2005, 09:45 AM   #36 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
myprojectB13,
I do not know if you actually checked this but...
are the Drain/Fill plugs interchangeable between the two trannies? Thas is, are their dimensions identical or very close and the thread identical so one could use the P11 ones on a B13 tranny?
Chris
Old 01-22-2005, 12:22 AM   #37 (permalink)
Feedback Score: 3 reviews
What precisely is RS5F70?
Nevermind.
binky is offline   Reply With Quote
Old 01-22-2005, 01:08 AM   #38 (permalink)
I may have missed this but does anybody know if the B15 axles from this SR transmission are any stronger than our B13/B14 axles?
'97 SE-R with BB T25 setup, G20 ECU, E-Manage, Starion FMIC, SPEC 6 puck stage 3 clutch, KYB AGX's, fully shaved doors including side molding, Royal Sapphire Pearl (Toyota Supra) paint, Stock headlights (Halo headlights included), Aerogear vented hood, 98 Sentra Grille, modified stock front bumper (Vis Extreme front bumper included), Andy's Autosport rear bumper, and Kenwood Excellon CD player
Tomcat5678 is offline   Reply With Quote
Old 01-22-2005, 04:20 AM   #39 (permalink)
GTIRoids
Feedback Score: 63 reviews
Tomcat5678 I may have missed this but does anybody know if the B15 axles from this SR transmission are any stronger than our B13/B14 axles?
That's good and I'd like to know that answer myself.
hpro123 Quote:
myprojectB13,
Chris
Not sure about the drain plugs but I do know that the reverse and nuetral switchs are different between the B15 & B13/B14 trannys
Specialist-V Do you have any extra pics of the install preferebly the grinding
of the tranny.
Hit me with a E Mail at
yesous2@comcast.net and I'll show you what I had to gring for fitment on the B14.
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 01-22-2005, 10:29 AM   #40 (permalink)
Originally Posted by hpro123
myprojectB13,
Chris
I'll check tomorrow. They look to be the same size but the threads could be different. Personally I would much rather use the B15/P11 plugs because they are hex heads instead of the square plug. These will be much harder to strip out. The only downside is you have to find a 14mm allen somewhere, which I was told Autozone carries a set with the 14mm.
