HOW TO: P11/B15 transmission swap into a B13/B14/P10 - Page 26 - SR20 Forum
Old 03-15-2010, 11:13 PM   #501 (permalink)
GTIRoids
Feedback Score: 63 reviews
Originally Posted by infam0usndn2nv View Post
i am not ***** thread jack....but i got a question for u guys since i am new in this....i am ordering a p11 lsd tranny frm a 99 g20 today....i will be doin the swap this week in my b13 but i need to *** exactly which axles will fit *** this swap...i read alot of stuff on this swap but still confused wheather the b13 axle are gonna fit or any diff 1
If your B13 is an NX2K or SER use your axles
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 03-16-2010, 11:02 PM   #502 (permalink)
Boost Gets You Laid!
so is it a must to change out the speed sensor to the cars original or can the harness/plug be rewired or something?
95 200sx SE-R (BB det/gt28rs/tb 3" exhaust/magnaflow/550's/z32 MAF/walbro fp/Blitz DD bov/Tein Basics/B15 LSD/mishimoto Rad
13.40 @ 113mph (on fully inflated winter tires)
Rockett is offline   Reply With Quote
Old 03-20-2010, 06:35 PM   #503 (permalink)
HELPPPPPPPPPPPPPPP...................I JUST GOT MY 99 infiniti g20 P11 tranny today.....but i compared it frmt he pics posted on this thread and its a lil diff.....did i get the right tranny or not??
infam0usndn2nv is offline   Reply With Quote
Old 03-20-2010, 07:32 PM   #504 (permalink)
Feedback Score: 108 reviews
Nope. 99 isn't the same as the 1 we are discussing here. Its still like the earlier box.
Old 03-20-2010, 10:51 PM   #505 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
LoL powned
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Old 03-20-2010, 11:15 PM   #506 (permalink)
so0o the 99 tranny cant be used???
Old 03-20-2010, 11:16 PM   #507 (permalink)
Enemy of the stupid
omg. The 99 is just like the 91-98 this guide will not help you. Just bolt it in and have fun.
Old 03-20-2010, 11:24 PM   #508 (permalink)
is it still good for boost thoo? will i have any problems like 5th gear poppin out or i just wasted 5 bills on nothing
Old 03-20-2010, 11:30 PM   #509 (permalink)
Enemy of the stupid
u wasted 5 bills
Old 03-21-2010, 05:07 PM   #510 (permalink)
anyone know about the speed sensor?
Old 03-21-2010, 05:20 PM   #511 (permalink)
Enemy of the stupid
I put my old one in from my DE and it worked.
Old 03-22-2010, 11:34 AM   #512 (permalink)
Speed sensors are interchangeable. Use the one that is for your car.
Old 04-16-2010, 12:26 PM   #513 (permalink)
i dont know if this was posted already or not but, for anyone looking for the harnesses for the neutral/reverse sensors, i looked at part numbers from all b15 sentras and they all use the same sensors/plugs, i went to a pick n pull yesterday n got them off a 2002 spec-v, and they plugged right in, now i just have to wire them into my harness.
Old 05-28-2010, 01:17 AM   #514 (permalink)
im having a problem with the throwout bearing closing completely now i cant see the picure on page 4 "where it has to be grinded" can some one explain to me where it is or someone load of the picture of wher i have to grind thanks im really stuck in a grind also could i put my p10 throw out bearing or should i get a p11 one?
blownG is offline   Reply With Quote
Old 05-28-2010, 02:03 AM   #515 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
You should always use a new throwout bearing
...Currently down due to a clutch disc spring failure....
Old 05-28-2010, 02:05 AM   #516 (permalink)
haha, that's why it's called a "throw out bearing", cause you throw it out everytime you open it up.
Old 06-10-2010, 04:28 PM   #517 (permalink)
So I got the B15 swap done to my '92 and did not use the Limited Diff and had the axle replaced with a brand new B13 axle but the car shakes when cornering. I thought I read for non LSD B15 swaps, you don't switch the axle. Anyone give some input on probable cause?
noahman is offline   Reply With Quote
Old 06-10-2010, 04:32 PM   #518 (permalink)
if you went from lsd to non. then you needed the matching axles
Old 06-10-2010, 05:07 PM   #519 (permalink)
I don't believe I did have a LSD to start with but I will double check with my guy tonight.
This is the car I have http://www.sr20forum.com/cars-sale/2...-virginia.html
Old 06-10-2010, 06:10 PM   #520 (permalink)
Feedback Score: 31 reviews
Originally Posted by SE-Rawkus View Post
This should answer all the questions as to what needs to be grinded off the stabilizer to make the swap complete
Here are the piks I took...
B13...the shifter sits back further compared to the P11
P11...the shifter is closer compared to the b13
Area that needs to be grinded...
Pics are no longer good, anyone have pictures of this?
