well i bought the 99p11 so i dunno. I needed a tranny bad plus everyone wants 8 to G for a b15 or a newer p11 so.How exactly is this 99 p11 tranny the same as the b13-14 doesnt it have the same case as the b15 i know the gears ratios are the same as the se-r.Has anyone actually broke or stripped 3rd gear in a 99p11 tranny?
Sorry, the 99 P11 tranny is just like a B13/B14 or P10. It has the same design gearstacks, rear bearings, and reverse idler gear setup along with everything else. There may be some miniscule differences but nothing significant. The case is not the same as the B15 or 2000+ P11 as those trannys have the reverse idler gear pinned into the actual case along with many other design differences.
1999 SE-L SR20DET-- Sold!
Hangon. Too much flak. I get the impression that you use the appropriate axles for your recipient car, not from a donor car. If you have a '98/99 SE-L, doesn't that mean you'd need axles from a '95-97 SE-R (one with a VLSD)? I doubt that B15 axles would fit anything that isn't a B15.
-=|JP|=-
...but then again...my b13 axles fit perfectly inside my P11 tranny
__________________ Manny E.
523 whp & 409 wtq ---RETIRED
Which is what I'm saying. If you have a B13, use B13 axles. If you have a B14 or P10, use B14 or P10 axles. Don't use P11 or B15 axles unless you're putting them into a P11 or B15.
both drivers side axles. Tranny side and hub sides do have slight differences...and for the record, www.raxles.com will make hybrid axles, so if your putting a B14 tranny into a P10 you can get those axles made.
I saw where Trans RS5F50V was mentioned in this thread ..... but I could not find the actual specs & gear ratios on this..... I found one with that code on it and know its a B15..... but am not quite sure what the specific code means.... any additional help would be appreciated.... Thanx
I think that the next thing to watch for is the SE-R Cup guys to use this transmission. Then we'll know how much power they can take, rather, for how long they can take power.
I think that we need to see if a clutch-type coupler or ATB device will work in this transmission next...
I want to use the P11 tranny on my race car. My only concern is if the Quaife unit that I use in my B14 tranny will fit inot the P11 00-02 tranny.
I called a dealer that is very helpful and he told me that the VLSD part number is the same for the B14 tranny and the P11 tranny, but the final drive part number is different. From the looks of the tranny case for the P11, it seems that Nissan went with a smaller final drive in size to make it fit. The FD ratio, however, stayed the same for the B14 and the P11.
1998 SE-R, 2008, 2009, & 2010 ITA Champion, SoPac Region
2002 Toyota Tundra V8 SR5, tow truck, 207 hp, 271 lb-ft
2010 VW Golf TDI
2007 Silverstone Honda S2000
I have a B14 VLSD+final drive unit and I would like any of you who will open your tranny in the future to give me the dimensions of the VLSD+final drive on the P11 00-02 tranny. That is the only way short of buying a P11 of knowing whether a B14 VLSD or Quaufe will fit into a P11 tranny.
the top one is a non LSD one, by the looks of it. the LSD ones have long splines to go through both parts of the diff.
Guys give this another few days, and I'll tell you about my experience in running the B15 2.0 VLSD trans with a 1.8 gear stack and 1st thru 4th with the 2.0 5th gear and the Nismo dif and ring gear from my B13.
"evidently the splines on the tranny axle imputs are all the same but the hub splines between B13, B14, P11 are different"
NX$paniard: I was under the impression that the biggest issue is axle length.
"I saw where Trans RS5F50V was mentioned in this thread ..... but I could not find the actual specs & gear ratios on this..... I found one with that code on it and know its a B15....."
Stackdaddy: The RS5F50V is an older Maxima transmission. I've never seen it used in a Sentra, but it'd probably fit with enough welding and grinding.
"Guys give this another few days, and I'll tell you about my experience in running the B15 2.0 VLSD trans with a 1.8 gear stack and 1st thru 4th with the 2.0 5th gear and the Nismo dif and ring gear from my B13."
Once again, Greg Vogel is my hero. I just want to know if you can get over 60 MPH in second gear with a 205/45-16 tire...which it looks like you could.
Whoa, wait a minute Greg. Thought of something after we talked today regarding the final drive. I understand you are moving the B13 ring gear over BUT that engages the pinion gear which is part of the main shaft. They have to both match or be the same set if you will. So you must be using the B13 main shaft, and sliding all the B13 1-4 gears off, then sliding all the 1-4 1.8 gears on, then using the 1.8 input shaft, and finally using the 5th gear input and main shaft from the 2.0 B15 tranny?
'97 200SX SE-R GT28RS Powered
'06 Mitsubishi Lancer Evolution IX
'09 BMW 335i E90
does this apply when intstalling a non-lsd trans, too? I'm confused, I think. if not, which axles?
'92 white se-r: de+t t25, fmic, b15 trans, cat delete, hks cat-back (ugh), safc-2, u13 ecu, smc sts, hypers/agx, random other stuff not worth mentioning...
'90 red s13 hatch, bone stock for the time being.
"I assure you officer that despite my person-like appearance, I am in fact a donut, so feel free to f*#king eat me."
If you're putting a B15 LSD transmission into a B14 SE (no LSD), the impression that I get from this thread is that you need B14 LSD axles. If you're putting a B15 Non-LSD transmission into a B14 SE, then you need non-LSD axles. Use the axles for your FINAL application, NOT your donor or even your recipient. If I'm getting this wrong, oh wise ones, PLEASE correct me. This is just the impression that I get.
