HOW TO: P11/B15 transmission swap into a B13/B14/P10 - Page 8 - SR20 Forum
Old 04-29-2005, 02:45 PM   #141 (permalink)
Simian Rex
They're the same dimensions and splining; the B15 kit superceded the B13/B14 application in the parts catalog several years ago. Don't get a Key Value clutch kit from a Nissan dealer, though; get the "real thing" if you go with OEM. I'd personally step up just a little bit to a JWT or ACT clutch.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 04-29-2005, 08:23 PM   #142 (permalink)
RNN14 @ 15 psi
So, if I ordered lets say from clutchmasters with application for a 1991-1994 SE-R, it will fit onto the B15 tranny right? I mean everything like pressure plate clutch disc, throw out bering and etc..?
Thanks
Dennis
You like PIE?
Dlove3:16 is offline   Reply With Quote
Old 05-01-2005, 04:55 PM   #143 (permalink)
I Keep It Unique
Feedback Score: 25 reviews
Originally Posted by mr.sentra_specv
the switches can be rewired all they are is a pos and neg wire (my way of explaining) so just hook em up i dont think it matters the colors to much. did in my b13 and the tranny nutral switch and backup switch work fine.
on the B15/P11 tranny which is the neutral switch which is the reverse? And the same for the B13 tranny which is the one with yellow wires coming out of it and which is the one with the black wires coming out of it?
Now Metal Fabricating, Welding And Powder Coating. PM Me With Your Needs!
sinistersntra91 is offline   Reply With Quote
Old 05-04-2005, 10:56 PM   #144 (permalink)
Feedback Score: 35 reviews
i just bought a non lsd b15 tranny for 350 shipped to my door. i am gonna put a friction lsd in it. the cheapest i could find a b15 with locking was $750. who sells raxles the cheapest?
cutter is offline   Reply With Quote
Old 05-06-2005, 01:24 AM   #145 (permalink)
bad ass sleeper
should have gotten the locker, mine bolted up in 2 days
nateb515 is offline   Reply With Quote
Old 05-11-2005, 05:29 PM   #146 (permalink)
Feedback Score: 47 reviews
okay, quick question...my 00 P11 tranny is crunching into 3rd...I think my syncros are bad...I can get a used nonlocking B15 tranny for reasonable, think the internals will swap over? or at least the parts I need...or maybe the whole gear set, or just swap out the entire tranny...
Old 05-13-2005, 06:08 PM   #147 (permalink)
GTIRoids
Feedback Score: 63 reviews
I was thinking to use the case of the P11 and the gear stacks from the B15. Can anyone verify that this is doable???
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 05-13-2005, 06:44 PM   #148 (permalink)
easy 400WHP
Feedback Score: 36 reviews
what about LSD options? would they be the same as the B13 Trans or will it require a different unit for upgrade. I just scored a P11 Trans and was curious to see if I could throw a Phantom Grip or Nismo LSD in....
~jRod
Old 05-14-2005, 02:28 AM   #149 (permalink)
Grandma's gonna get ya!
coalitionSE-L's Avatar
Feedback Score: 6 reviews
I would go with yes on that. The gearstacks should be interchangeable.
1999 SE-L SR20DET-- Sold!
Old 05-14-2005, 02:30 AM   #150 (permalink)
From my experience tearing the B15 tranny down, I discovered that the B15 VLSD is identical to the B13. Reason why I can say that is because I had a spare B13 VLSD laying around and compared the two.
B15 Phantom grip install: http://www.sr20forum.com/driveline-transmission/103882-disassembly-b15-p11-tranny-install-friction-type-lsd.html
Old 05-14-2005, 03:29 AM   #151 (permalink)
Keeping It Real
So it's a safe bet to purchase a Nismo diff and it'll fit fine?
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 05-14-2005, 10:02 PM   #152 (permalink)
Feedback Score: 9 reviews
Thanks Jonathon for starting this thread.
I wanted to add something I found while converting my P11 to cable. On my specific tranny (2002 G20, locking) there is a insert where the clutch arm rests in
comparing to a B13
Some quick measurements on the lip above the insert show that without the insert the mounting/pivot hole for the arm is the same diameter as my B13 tranny. So maybe grinding of the B13 shaft might not be needed, only removal of the insert.
After removal of the insert, the grinding of the B13 arm is NOT needed.
Chris M
Va Beach, VA
91 Classic Turbo (parting out )(12.19@116)
93 NX2000-work in progress
Projnx2000 is offline   Reply With Quote
Old 05-15-2005, 02:40 PM   #153 (permalink)
easy 400WHP
That was very well done, Coalition!!!!!!
So I saw you used the JGY LSD or whatnot was it the same as the B13 Phantom Grip??
Old 05-15-2005, 11:11 PM   #154 (permalink)
Thanks. I don't know for sure if they're the same, but I imagine there isn't much difference. It's a simple concept.
Old 05-15-2005, 11:56 PM   #155 (permalink)
easy 400WHP
so when u ordered it from JGY, you asked specifically for a B15 one? Did it say anything on the package it came in???
Old 05-15-2005, 11:58 PM   #156 (permalink)
The pinion shaft, spider gears, and housings from the B13, B14, and B15 VLSD's are the same. There's not a special one for the B15.
Old 05-16-2005, 12:00 AM   #157 (permalink)
easy 400WHP
Thank you sir!!!!
I better start looking for one then
Old 05-16-2005, 07:28 PM   #158 (permalink)
myprojectB13's Avatar
Feedback Score: 17 reviews
comparing to a B13
Good find. So it looks like this install is a complete bolt on affair. I think I might just have been a little grinder happy.
Jonathon
1996 G20
1993 SE-R 13.35@102
Old 05-20-2005, 12:47 AM   #159 (permalink)
The Gingerbread Man
thanks
NX-t is offline   Reply With Quote
Old 05-23-2005, 08:44 PM   #160 (permalink)
I just finished my P11 install, another note-
Even if the shifter link is flipped, it would still not clear the stabilizer rod- (hits on back of the mounting stud for the rod). BUT you would not have to grind as much. I only ground down the stud backing about 1/2 way and the bracket from the stud down to about the same level. No clearance issues sitting in the driveway.
