HOW TO: P11/B15 transmission swap into a B13/B14/P10 - SR20 Forum
Old 11-26-2004, 10:35 PM   #1 (permalink)
myprojectB13's Avatar
Feedback Score: 17 reviews
How-To: P11/B15 Trans into a B13/B14/P10
I finally finished installing a P11 transmission into my B13 and thought I would do my best to make a how-to guide for others interested in doing the same. I had read many times over that this was a simple bolt on affair with a simple swaping of a few parts, but found out myself that it is slightly more involved. There really isn't anything difficult about it, but there are some modifications that need to be made. In my post title I'm assuming that the P11 and B15 transmissions are identical. I'm also hoping that Slow96R and SR20Turbofreak will chime in with the specifics for the B14 and P10 respectively.
Clutch Cable Bracket
-The first thing you'll notice on the P11 trans is how the clutch is actuated differently. The P11 uses a hydraulic slave cylinder to engage the clutch instead of a cable.
-Simply unbolt the slave cylinder.
-You can see the holes are there to mount the clutch cable bracket from your B13. The rear set of holes is set back further than on the B13 and may allow those using small spacers to completely eliminate the spacer.
*On my specific car, my spacer and the rear holes made for too tight of a clutch cable. I used the front holes, which have a slightly different pattern, and required drilling the holes on the bracket larger. I also needed to notch the bracket to keep it from hitting the clutch arm.
Clutch Arm
-Remove the clutch arm in the P11 trans by removing the roll pins(arrows).
*There is an inner and outer roll pin, remove the inner first then the outer.
-Do the same to your B13 trans.
-Here you can see the differences between the two clutch arms.
-The most important difference is the difference in thickness at the bottom of the shaft. This prevents the B13 arm from seating fully in the P11 trans and doesn't allow the throwout bearing to line up properly.
-To fix this I used a bench grinder and carefully removed material from the B13 shaft.
-Since the B13 arm sits in a completely different location than the P11 arm, the vent tube had an interference problem with the weight on the B13 arm. Nothing an angle grinder can't fix.
-Install the B13 arm into the P11 trans. Don't forget the return spring from the B13 trans.
*Install the outer roll pins first then the inner pins.
-It's now ready to go in, almost...
Motor Mount
-The P11 uses a different trans mount than the B13. It uses a top mount that uses 4 bolt holes on the top of the trans(black arrows).
-Lucky for us the trans is still drilled and tapped for the B13 trans mount(white arrows).
*The holes were pretty dirty so I used some antiseeze on a bolt and ran it through the holes. You could also use a M10X1.25 tap to clean them up.
Speed Sensor
-Simply undo the electrical sensor on the P11 and replace it with the B13 sensor.
*This is for 91-93 cars with mechanical speedometers. I do not know if the P11 sensor is compatible with the electronic speedometers in the B13.
Drain/Fill Plug
-The P11 uses a 10mm allen to remove the fill plug and a 14mm allen for the drain plug vs. the B13's 3/8" and 1/2" tools.
Sensors
-The reverse and neutral position sensor from the B13 are sized differently than the P11 sensors and can't be swapped. The harnesses are also different.
*I've yet to tackle this, but I plan on rewiring my B13 with the correct harnesses to fit the P11 sensors. Stay tuned for wiring details and part numbers.
Shifter rod/stabalizer
-This is where it becomes not quite a bolt on affair. On the P11 the shifter stabalizer mounts to the trans, where as on the B13 it mounts to the rear motor mount.
-Remove the bracket from the trans.
-Because of this difference the shifter rod sits further to the passenger side and interferes with the B13 stabalizer rod mount.
-This requires some major grinding and is alot easier to do with the trans out of the car. I grinded enough off until I could get the trans to bolt up.
-I thought I had grinded enough off, until I bolted up the rear mount. With the motor in its final position, the stabalizer mount was still hitting on the shifter rod.
-I trimmed a little off the shifter rod until it fit.
*This was the hardest part of the whole install, but overall not that difficult. Pictures coming soon.
Hope this helps people contemplating the swap. This will be my 4th trans since March, so I was willing to try something a little different. Slow96R, SR20Turbofreak, and javierb14 have had good luck with this trans and big power, so I hope it works out for me.
EDIT:
B14 - From what Slow96R told me, you need to do the same modifications for a B14.
P10 - From what SR20Turbofreak told me, on a P10 you won't have a clearance problem with the stabilizer mount. This is because the P10 uses a different crossmember that sits more to the passenger side giving you the clearance you need.
Jonathon
1996 G20
1993 SE-R 13.35@102
Old 11-26-2004, 11:03 PM   #2 (permalink)
stirring but plain-faced
Great info, thanks for taking the time to document the process.
Is there any way that the B15/P11 sensor ports could be drilled out and re-tapped for the B13/B14 sensors?
NoClassic is offline   Reply With Quote
Old 11-27-2004, 01:41 AM   #3 (permalink)
G-unit
Feedback Score: 8 reviews
Question: Do you use same axles as B13 or do you have to use P11 axles?
Travis E.
skyliner is offline   Reply With Quote
Old 11-27-2004, 01:47 AM   #4 (permalink)
B13 Axles
The write up lists absolutely everything you need.
Old 11-27-2004, 07:53 PM   #5 (permalink)
How can you tell a b15vlsd transmission from a b15 open diff transmission?? The junkyard isnt sure and the car is gone so i cant look at the A or V stamp.
NissanSpeed01 is offline   Reply With Quote
Old 11-27-2004, 08:50 PM   #6 (permalink)
GTIRoids
Feedback Score: 63 reviews
Just tell him to look at the seals. One should be much larger (2X) than the other. If they are the same size it's an open diff. Also he can look for the LSD hump as noticed in the above pic, but that's hard to tell unless you know what your looking for. Just remember to tell them to look at the seal that's on the side of the gear stack (trans body) and see what size it is. Even then sometimes they still don't get it right
Hey J thanks for the write up. I never would have been able to do this. U da man. Also sorry to hear about the break
Tec 3+ B15 trans +???
Slow 96R is offline   Reply With Quote
Old 11-27-2004, 09:43 PM   #7 (permalink)
Feedback Score: 21 reviews
This may be a dumb question, but can put a 6 speed into a b13?
sergofast is offline   Reply With Quote
Old 11-28-2004, 03:06 AM   #8 (permalink)
It's possible... Because the Primera 6spd has a SR bellhousing. You could get a Maxima or Spec V 6spd and use the Primera bellhousing. I think you have to use the funky dual mass flywheel from the SR20VE too.
Travis
Travis Burelle / Forced Induction Racing
VQ swaps, Engine builds, Turbo kits, Chassis work..
985-713-1542 (www.fi-r.net)
unlucky is offline   Reply With Quote
Old 11-28-2004, 01:43 PM   #9 (permalink)
Veritas
SERprise In WV's Avatar
Excellent job, Jonathon. If/when my B13 tranny goes, I'm using this guide to get the P11 setup put in there.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 11-28-2004, 04:15 PM   #10 (permalink)
meh
nice write up ive been using the b15 trans for a few months now. it's completely stock (no welding or cyro), uses MT90, and a ACT 6 puck with an extreme pressure plate (not the most forgiving clutch)...haven't had a problem yet
www.full-race.com
javierb14 is offline   Reply With Quote
Old 12-01-2004, 08:11 PM   #11 (permalink)
If you take the more agressive 4th and 5th (0.975 and 0.756) and add it to the B15 transmission you will end up with the same ratios as the SR16VE N1 transmission
Somebody check behind me and make sure I got everything right.
Old 12-01-2004, 08:59 PM   #12 (permalink)
Full Chart
Old 12-01-2004, 10:07 PM   #13 (permalink)
GTIRoids
This can't be correct?!?!? Can it????
Old 12-01-2004, 10:09 PM   #14 (permalink)
NissanSpeed01 - Can you do one comparing the B13 vs P11 since thats what I'm running. Or would you mind sharing that Excel sheet, tropicorange20v@yahoo.com. Thanks.
Old 12-01-2004, 10:14 PM   #15 (permalink)
I love Katamari
Feedback Score: 3 reviews
72+mph in 2nd gear doesn't sound right - appreciate the effort though
Bjorn is offline   Reply With Quote
Old 12-01-2004, 10:21 PM   #16 (permalink)
On Vacation
Feedback Score: 10 reviews
I don't think those Excel figures are correct.
I know the stock gauges aren't too accurate....but it can't be off by almost 10 MPH.
In 5th gear @ 3K RPMs...my speed on my tach indicates 60 MPH
Manny E.
523 whp & 409 wtq ---RETIRED
SE-Rawkus is offline   Reply With Quote
Old 12-01-2004, 10:21 PM   #17 (permalink)
Tire size has a factor. Measure your tires from tread to tread and I can change it.
Old 12-01-2004, 10:48 PM   #18 (permalink)
Which P11, the 99 or 00-02 model?
I just noticed i left the tire size specs setup for a DSM. I will change now
Old 12-01-2004, 11:02 PM   #19 (permalink)
Its a 2000.
Old 12-01-2004, 11:36 PM   #20 (permalink)
I just updated the charts
