Go Back   SR20 Forum > Classifieds > Electronics / Gauges
Old 09-19-2005, 11:26 PM   #1 (permalink)
NA bliss.
Tomei fully programable stand alone 800 bucks
I need cash REAL bad. I have a Tomei Reytec stand alone ECU for an S13 SR20DET, comes with all sensors, software and cables. All instructions in english. If you are somewhat local I will wire up the check harness for you to use this system, if not, I will include my notes that took a week of research to get and translate. System uses a MAP sensor so you can toss that restrictive MAF sensor. A badass ems that retails for over 3k, I'm selling for 800 bucks.
THIS DEAL IS ONLY GOOD AS LONG AS I NEED MONEY, might end tomorrow, might end in a few days.
SR20DE S13 280zx front end
Drift Assoc. LLC - Chief of Tech, tech questions? Richard Maertz
LOVEMUFFIN is offline   Reply With Quote
Old 09-20-2005, 02:23 AM   #2 (permalink)
natulog sa pansitan!
this would work on b13 fwd?
VvL powa!
kyoshoboy is offline   Reply With Quote
Old 09-20-2005, 12:29 PM   #3 (permalink)
NA bliss.
If you got the CAS and coil packs and the engine harness out of a RWD SR I see no reason why it would not. I will give you a CAS and the coil packs with it but I don't have an engine harness anymore. Plus you would have to mod the CAS to work in a FWD placement.
Going to look at a car tonight... deal might be over soon all you lookers!
