Go Back   SR20 Forum > Classifieds > Electronics / Gauges
Old 02-24-2006, 01:52 PM   #61 (permalink)
I researched the consult wires last nite based on the service manual of a 99G20 and a 91 service manual. Wire 7 goes to 64, 14 goes to 68, 15 goes to 65. 23 is another consult wire which doesnt get used on the OBDII plug... leaving 4 wires that are unused on the OBDI plug.
In regards to those who used the harness, I tried starting my car with the 91 ecu and the idle stays pretty high at 2300rpm... Let it run for a minute only. Since mine is a 99, is it necessary to disconnect the MAP sensor? or anything else? Or adjust the timing and idle for the new ecu?
SucKit is offline   Reply With Quote
Old 02-26-2006, 06:53 PM   #62 (permalink)
The DET is in!
Trader Rating: 17 (100%)
If I'm swapping a DET into my B13 then I don't need one right?
RedDragun is offline   Reply With Quote
Old 02-27-2006, 06:50 PM   #63 (permalink)
P10 pro
Coalition, what's the final word on the consult port? Can you use the NisdataScan Display Module with the adapter?
5speed is offline   Reply With Quote
Old 02-28-2006, 12:53 AM   #64 (permalink)
Grandma's gonna get ya!
coalitionSE-L's Avatar
The vehicle does not have a MAP sensor. You do not need to disconnect anything, the idle is unrelated to the wiring harness adapter. It may be idling high for warm up and will probably drop after operating temperature is achieved.
1999 SE-L SR20DET-- Sold!
Old 02-28-2006, 12:54 AM   #65 (permalink)
Well, think about it. If you have a B13 harness, then you would not need an adapter to convert to a B13 harness.
Old 02-28-2006, 12:55 AM   #66 (permalink)
No final word yet. I have heard of about 4-5 different people saying that they wired it up for CONSULT but no one follows up and says whether or not it works.
Old 02-28-2006, 03:48 PM   #67 (permalink)
I hooked it up, but i dont have any way to test it. Anyone can feel free to test it on my car.
Clean a$$ hell red 200sx.
Old 02-28-2006, 04:22 PM   #68 (permalink)
Weekend Warrior
Trader Rating: 33 (100%)
Let's say my 1.6L which is a (auto), would I just need to give you the wiring harness from my (auto) 1.6L and a (manual) ECU from a 91-93 Highport SE-R or would you need my 1.6L ECU as well?
BEND BUT DON'T BREAK
93 SE-R
Project-4Door-B13 "Building it one paycheck at a time"
FB1 - FB2 - SR20 storage building part-out LINK
MR-4Door-SR20DE is offline   Reply With Quote
Old 02-28-2006, 05:16 PM   #69 (permalink)
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 22 (100%)
I will confirm that. For the record:
OBD1 ----- OBD2 ---- Name
14 --------- 68 ------ CLK
15 --------- 65 ------ RX
64 --------- 7 ------- TX
...and if your hard wiring a consult adapter into the adapter harness directly splice (note: do NOT plug a consult device into the real consult port if you've hardwired a consult box into your adapter harness, that would be silly!):
47 -----------*------- IGN
39 -----------*------- GND
calum@calumsult.com
Old 03-01-2006, 09:28 AM   #70 (permalink)
I don't understand what you are asking, can you re-phrase that?
Old 03-01-2006, 09:53 AM   #71 (permalink)
Weekend Warrior
Sorry that was typed weird. I have a 1.6L and I want to know what I would need to supply for you to make a harness for $130 for a (manual) Highport sr20de in the future?
1.)My 1.6L engine harness?
2.)A manual 91-93 ECU?
Old 03-01-2006, 10:11 AM   #72 (permalink)
What are you wanting to accomplish? I have to understand what it is that you are trying to do in order to help you. I don't do 1.6 to 2.0 conversion adapters.
Old 03-01-2006, 12:26 PM   #73 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
If anyone needs a B14 ECU for this project, please PM me. I have one for you! That is all.
Old 03-01-2006, 01:53 PM   #74 (permalink)
Trader Rating: 18 (100%)
pm sent
B15 SE one day it'll be boosted...
I'm trying to set the record for the longest build
Victorious is offline   Reply With Quote
Old 03-01-2006, 02:17 PM   #75 (permalink)
Weekend Warrior
O.....My bad Coalition, I thought you could use the wiring harness from a 1.6L and rewire it to fit a 91-93 ECU on a sr20de...sorry for the confusion. I misunderstood you a bit. I need to read this thread from the begining.
Old 03-02-2006, 02:06 AM   #76 (permalink)
I can use a 1.6 plug to make the adapter, but you have to run an SR20 harness. Again, what is it that you want to accomplish? By that I mean what year car do you have, what harness are you running, and what ECU is it that you are wanting to run? I have to know this stuff in order to answer questions. I get untold numbers of PMs and stuff each day about these adapters so I apologize if you have told me before and I forgot.
Old 03-11-2006, 12:24 AM   #77 (permalink)
Just an update, adapters are now available for the B15/P11. I will update the original post soon with complete details.
Old 03-11-2006, 12:49 AM   #78 (permalink)
FWD PWNAGE IS HERE!
P10?
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Beating up the streets of SL,UT.. watch out - 334WHP/313TQ
www.UtahNissans.com
www.RallySportDirect.com
SR20 Inside is offline   Reply With Quote
Old 03-11-2006, 01:39 AM   #79 (permalink)
Originally Posted by SR20 Inside
P10?
What year?
Old 03-11-2006, 02:17 AM   #80 (permalink)
FWD PWNAGE IS HERE!
