I have a B13 with a bad circuit board. If anyone need it for the connector, shoot me a PM.
A B13 ECU connector is of no value. You need a B14 ECU connector and a B13 ECU harness. I have both of those but decided not to go through with the swap. I have both for sale, if anyone is interested.
1991 Sentra SE-R
im putting a gtir into a 95 200sx.
alright well im not good with wiring. the way that its sounds it that i can use my gtir wiring harness and use the gtir ecu and by using ur product it will hook up the dash hook up as well???
it uses stock b13,gtir,u12,u13 ecu so yes your cluster will still work an your rev limit will be 7500k.
Danny GDM (HKS)
1993 PRiMERA GT
I have been receiving tons of PMs about these and figured I might as well announce this in this thread. At the present time, I am way too busy to make these adapters. This is not to say that I won't be making them anymore at all, but for right now until further notice, I am unable to make these due to VERY limited free time.
Remember that full, detailed instructions on how to make these adapters can be found on my website: http://www.roastedpavement.com
hey just wondering if i am get some info on the adapter like what to do with the numbered wires and what wire needs to be wired in the distibutor. i have ab15 to b14 connecter.
cheers
rob
numbered wires? i have a wire for the distr but no numbered wires... any ideas? ths is on a b14-p11/b15
Don't worry, he has a unique plug that I had specially made for someone's specific application. He bought it off of that person. The numbered wires were wire leads that I had spliced onto various pins on the B14 side so that it would be easy for the original owner to wire up an S-AFC.
