Originally Posted by smokeahonda
i just have a question!
you talked about other sellers offering 2year warranties but did not talk about yours? i would like to get that clarified please!
and how can i make sure as a buyer from you that your HID conversion is classA?? since all HID look and perform the same!
i was trying to compare this to www.wholesalexenonHID.com, because i was planning to buy from them until i bumped up to your thread!
the only thing i currently see is the price!
just want to get some s**T clarified man! thanks alot!
You just bring a good point, thank you.
The main trick on the HID kit is how a seller can easily void you a warranty or tell you that you need to send it back to the manufacturer. Per example I can offer you 3 yrs warranty but I do not tell you how it works, you buy them and as soon as you get a problem with them, you find out you are all alone byself.
I offer 6 months DIRECTLY WITH ME INMEDIATELY REPlACEMENT because of the following:
Basically, most of electrical parts do not have warranty, however I will honor it during the whole time no matter what, except physical damage is shown or some kind of abuse or misusage (cut wires, etc). If it fails, as soon as you send me back the part and I check it, I will inmediately return it to you. You have seen all the problems many members have gone through because sellers just keeps telling them excuses, this does not happens with me.
The HID kit has 3200 hrs average life. As seller, I do not know driving habits so if you use it normally, it will last years, but if you abuse of the system by turning it on and off constantly or turning it on all times when you drive, this will reduce the expected days of usage. If, per example, you use it 8 hrs a day it will last more or less a year, but if you use it 16 hrs a day (like a sales persons or else) it will hold for 6 months.
By the pictures found on their website. these are their ballasts inside:
So do your own conclusions...
Now, let me demostrate some of their lies to get you...
ADVANTAGES OF A Line Electronic Xenon HID LAMP KIT
"ALine Xenon HID Bulbs can provide more
then 6 times the amount of halogen bulbs, while only consuming half the power "wattage". Therefore, the driver can also see more clearly and the car has more power. The polar white light produced by the Xenon HID bulb is similar to daylight. Due to their electrical engineers research has shown that this enables drivers to concentrate better. Their ALine Xenon HID bulbs life is more then 3500 hours, which is around 20 times of the halogen tungsten lamp. Also their Xenon HID System are
MADE IN JAPAN."
Here you find 2 simple facts:
Light output is measure in lumens, typically a halogen bulb outputs 800 lumens at 55 watts while a xenon bulb @ 35 watts 6000ºK color outputs aprox 2800. With this on mind, you find out that a Xenon HID bulb outputs aprox 3 times the light output. The only way to increase output on a Xenon bulb of this kind is by adding more power to it (this is the reason of the 50 watts kits which at the end, the output gain is no more than 8%). A OEM system from factory on luxury or sports cars use 4300ºK and they output 3200 lumens.
How this vendor can they say a 35 watts xenon bulb can output 5600 lumens? FALSE.
Secondy... they claim they are Made in Japan... FALSE.
These kits are CUSTOM MADE for a US Customer made by
Shanghai Lantsun Electronics Co., Ltd. in CHINA.
Check their box
Check lantsun box
Check the logos, they are pretty much the same ones and on the same order!!! This is because they only change the image and the name on the boxes. They also sell these ones too:
http://www.lantsun.com/index.php?con...t&parent_id=11
It's just a matter of paying for the packing of at least 500 kits and you can put the image, logo, name, etc as you want, they will do it.
A true japanese kit cost at least 500 dlls like this one
http://www.fet-japan.co.jp/catz/products/hid/index.html
As buyer, you need to trust your seller, but most important, do your own research. Hylux is the best Chinese ballast and CNlights are the best chinese bulbs and you will get them both on my HID kits. If Hylux ballast is not available, you will get the Exsun ballast, china's 2nd best ballast supplier, both are way more expensive that 2nd quality ballast mostly found on all HID kits.
All pics you have seen from my kits were taken by me on my own kits. I don't think you will find a HID seller like me that also has a green belt certificate from Motorola and that know about quality this much
I am tired, it's 5:17 am here, time to sleep
If you have more questions, I will glady answer them.
