B13 basic daughterboard and 2 chips & up to 2 bins, $140 installed on your ecu.
We moved into our new place finally in Orlando, FL. I can get as many of these boards as needed.
This board can switch between 2 bin files. Example...basic sr20ve with ve cams program and sr20ve n1 cams program.
Switching between bin files is just a matter of lifting the little red jumper switch, and reinstalling it. Look at the pic, see the red jumper? It fits on the "jrom", on the board.
I can only get B13 boards at this time. The bin files you request must already exist, I don't create any. I can set rev limiter and max out the speed limiter. I can turn on/off both the knock sensor and oxygen sensor.
"I am the gatekeeper of my own destiny and I will have my glory day in the hot sun." - who said that?
It's $140 installed and returned by usps priority mail, using your ecu.
All you have to do is choose one of the bins. Or, keep searching for just the right bin. And, tell me where to set the rpm limiter. I assume you'll want to max out the speed limiter.
I mounted the board in a working ecu, ready to ship out with your tune. $200, or $140 with exchange. Exchange is a good working ecu (b13/p10) that you send in and I test to work fine.
do u tune also? if so how much would u tune a 11.2:1 b13 with cams n a n60maf on e85?
I don't do tuning. Can only do the basic mods like turn on/off the knock and O2 sensor, raise speed and rev limiter. Also, can raise idle speed for you guys with big cams.
I have one obd1 ecu ready to go right now. Will let it go for $160 shipped, contains the daughterboard and set of chips. You choose the tune(s) and I'll set it up for you.
Sorry, been away for a while taking care of college courses. I've done a quite a few ecu's now.
Still have an ecu ready to go if anyone needs it. After Thanksgiving I'll be busy again and won't be able to get on here much.
hey just had some question about this im looking for a plug and play solution for my g20 that i can later upgrade. right now i have a lowport sr20 with a t28 turbo 370 injectors and n60 maf everything 255 fuel pump. my car is 0bd2 so i know i need a step down harness but would you beable to do something for this set up, also if you can is it a matter of plugin up and drive like the jwt ecu or do i need to take it to a tuner and how do the modify the program if its already burned i am clueless when it comes to these things any info would help
