I have for sale a used 4 cylinder Electromotive TEC3 Engine Management System. It was used on a Subaru Impreza. Used for about 10 hours. I am going back to stock to trade my car in for a BMW M3.
Full information can be found at:
http://www.getfuelinjected.com/products/tec3.html
The new TEC³ represents the current in state-of-the-art fuel injection and direct ignition control integrated into one revolutionary package. The TEC³ is a PC-programmable engine control system featuring a powerful Windows-based tuning environment. Converting from carburetion to fuel injection has never been easier than with the TEC³. Whether you choose to run throttle body injection, multi-port, or individual throttle bodies,the TEC³ will provide you with the ability to tune your engine to its peak capabilities.
What you will be bidding on is a complete 4cylinder kit with:
1 - 33400.... TEC³ Direct Fire Unit DFU for 4 cylinder Applications
1 - 070-33000....TEC3 ECU. 8 injector driver, 4 coil drivers. Use on most engines up to 8-cyl. Also works with 1- and 2-rotor engines. Includes software, com cable, and manual.
1 - 070-33100.... Unterminated harness with two 23-pin connectors and 2-pin ECU Power Connector (for Standard TEC3, NOT the 6/12)
1 - 300-71110 Manifold Absolute Pressure (MAP) sensor, 1 bar (Normally Aspirated)
1 - 305-71210 Coolant (CLT) sensor
1 - 305-71220 Manifold Air Temperature (MAT) sensor
1 - 315-72120 Heated Exhaust Gas Oxygen (HEGO) sensor, 4 wire
1 - Your choice of: 230- Universal Trigger Wheels - All Trigger Wheels are 1/8" (0.125", 3.175mm) Thick
1 - 72218 Mag. Sensor NEW, 1/2" Diameter WITH connector
Misc Connectors for MAP, MAT, CLT, HEGO, and Mag. Sensor
If you go here:
http://www.distributorless.com/pdf_f...pricesheet.pdf you will see the price sheet from Electromotive for these parts. So if you do the math, the kit goes for over $2300 Dollars. I accept PayPal, Money Orders or Cashier's Check only.
