Old 11-25-2007, 01:24 AM   #1 (permalink)
TREYDEE
WWJD
Is a AFCI an ok temporary solution?????
I was wondering will I be okay running a AFCI at first with my set up til I figure out what I wanna use for good?????
Car: 99 G20T Man.
Comp: 97 SE-R Man.
Set-up: VE head on a DET
Also if I wanted either a Calum or JWT, what should I look for??? do I need a DET program or a VE program????? Anybody got an idea about what the compression would be????????
91 Gxe auto(SOLD)
91 Turbo SER(CRASHED)
91 Turbo SER(SOLD)
01 Acura CL Type-S(TRADED IN)
04 Acura TSX(stolen)
06 GSXR 600(crashed via little brother)
92 VE Powered NX2000(SOLD)
99 G20T 5 SPEED (MY NEW BABY)
TREYDEE is offline   Reply With Quote
Old 11-25-2007, 04:18 AM   #2 (permalink)
BenFenner
Try keeping the question marks down to a minimum. We might be able to help you then.
Old 11-25-2007, 02:56 PM   #3 (permalink)
TREYDEE
WWJD
Any help would cool fellas
Old 11-25-2007, 09:17 PM   #4 (permalink)
TREYDEE
WWJD
bump
Old 11-25-2007, 10:28 PM   #5 (permalink)
Bowlcut
pwnd
what is that, 24 question marks for 3 sentences....great ratio if you ask me
-Kevin
We are a community
Bowlcut is online now   Reply With Quote
Old 11-25-2007, 10:53 PM   #6 (permalink)
BenFenner
I think it's going to depend on one, main issue. You could probably used the AFCI at first with your set up 'til you figure out what you wanna use for good if you find a way to work in a few more question marks with your current set-up. If you keep the question mark - to - question ratio high enough, you shouldn't expect to see any problems. Once you get near the one-to-one ratio, you'll probably see results you've never seen before.
Old 11-25-2007, 11:16 PM   #7 (permalink)
TREYDEE
WWJD
Lets get this right you guys are trippin because I use alot of question marks???????
I didn't know there was a SOP for how many question mark a member could use in one post, And if there is then whats the Max????????????
Old 11-26-2007, 12:26 AM   #8 (permalink)
BenFenner
15 question marks per post maximum. Looks like you just made it under the gun with your last one.
Old 11-26-2007, 01:06 AM   #9 (permalink)
TREYDEE
WWJD
Your Funny Ben
Just tell me, why you got such a hard on for these thing????????????????????????????????????????????? ??????????????????
Old 01-15-2008, 02:48 PM   #10 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
What is an AFCI?????????????????????????????????????????????? ?????????????????????????????????????????????????? ???
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 01-18-2008, 07:49 PM   #11 (permalink)
gtswrx
Trader Rating: 18 (100%)
Very informative thread
Loading...
gtswrx is offline   Reply With Quote
Old 02-10-2008, 09:32 AM   #12 (permalink)
clayk16
SE-R
I used one for a while just don't go turning the boost up and stuff. It will keep you rich but it's not the best choice for tuning. But I'm sure you already knew that
95 200sx SE-R
95 200sx SE
clayk16 is offline   Reply With Quote
Old 02-10-2008, 11:54 AM   #13 (permalink)
SENTRASER
SENTRASER's Avatar
What the crap is an AFCI?
Old 02-10-2008, 11:58 AM   #14 (permalink)
TREYDEE
WWJD
I meant S-AFC II
Old 02-10-2008, 02:43 PM   #15 (permalink)
bobbyisking
KASSANOVA!!!
Trader Rating: 37 (100%)
lol you never got an answer, just people talking about the question marks, lol. and is there really a point in rubbing the ??? into their face? i don't really think so.
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 02-10-2008, 02:47 PM   #16 (permalink)
Nyc Sr20PowerD
Trader Rating: 15 (94%)
lol wow, for ur info safc is good enough for a temporary solution just use a wideband to get teh af ratios correct
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
