Using jwt ecu as base map?
Basically guys this is the situation, I want to do a multi-map program for my se-r. I want an economy program for DD that focuses on max fuel economy rather than power. Next I'd like a normal program that would give me decent power on 87 oct, but I also want a program for E85. Now my jwt ecu is tuned for C2 cams, 370cc inj, 8k rev limit and n2o. The problem is they don't have an E85 tune since its not available in their area but it is where I am. Also a calum ecu can't store more than one program at a time so I'd have to use my laptop to switch between them.
I'm thinking of just sending my ecu back to jwt to get the n2o program removed and just get them to add a stock, POP and race map so I can just retune one of them. I've found that with my road dyno, I only use 24-35whp during DD so a program optimized for that power level should decrease my fuel consumption. Also if I go to the track I'd like to run E85 so I can get the most power for when I need it. Has anyone ever retuned a JWT ecu? Outside of buying a stand alone or keeping a laptop with me at all times, there doesn't seem to be a better way to get the tunes I want. Is selective cylinder deactivation out of the question as well? I did a few trial runs with an injector unplugged and my o2 sensor unplugged so the ecu won't think its running lean. The car did have less pick up but nothing that would cause a problem.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
