Old 01-03-2008, 04:52 PM   #1 (permalink)
kungfujerry
SR20 wiring harness TPS
Ok I got the red top sr20 and "new" wiring harness from jazzproparts.com, but there is one discrepancy; the throttle position sensor plugs do not match up. This wouldn't be a huge issue except the harness plug has a 3-prong connector and the TPS has a 6-prong connector. I don't know what to do. 3 wires can't just be missing. Anyone have suggestions besides buying a $300 new wiring harness?
kungfujerry is offline   Reply With Quote
Old 01-03-2008, 11:54 PM   #2 (permalink)
BenFenner
Get a new TPS that takes 3 wires? =]
Old 01-14-2008, 01:35 PM   #3 (permalink)
Mike I am a moderator
_______
Mike's Avatar
Trader Rating: 54 (100%)
From the sounds of it the harness you got it from a MT car and most likely the tps you have on the motor is from an auto (90% of imported det's are autos). The auto has a tps and a closed throttle sensor on the TB. The plug for the sensor is different between the two. You should just be able to swap on a mt tps and be done with it.
Mike
Mike is offline   Reply With Quote
Old 01-15-2008, 02:43 PM   #4 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Yup...swap ur TPS
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
