Old 01-06-2008, 09:03 PM   #1 (permalink)
Born2Ride
SE-R on a budget
Consult cable with calum ecu?
I have a calum ecu, will a consult cable do me any good or can I monitor my car off of the ecu plug? All this ecu,consult,tuning is confusing to me....sorry
Born2Ride is offline   Reply With Quote
Old 01-07-2008, 08:52 AM   #2 (permalink)
nsusammyeb
officially a boost addict
you can use the regular consult port under the dash.
'96 se-r bluebird swap.
It's a WIP, work in progress. Exhaust and paint coming soon.
T25's feel too small real quick don't they??
nsusammyeb is offline   Reply With Quote
Old 01-07-2008, 09:52 AM   #3 (permalink)
Born2Ride
SE-R on a budget
So what exactly is the purpose of the plug on my calum ecu? I have the calumsult downloaded on my laptop,I thought I could plug my laptop into "calum" plug and monitor my car......
Old 01-08-2008, 05:14 PM   #4 (permalink)
Yellow4g63
Enemy of the stupid
The Basic Ecu you would need the consult cable, realtime ecu you don't need the cable. COM6 or 7 should be the Consult port for the software. Nistune,calmslut ect. THere all going to ask you which com port is the cable on. Hmm hope that helps you out.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 01-08-2008, 08:34 PM   #5 (permalink)
Calum
soylent green is people
Calum's Avatar
Approved vendor
Trader Rating: 22 (100%)
Exactly which type of daughterboard do you have? Is the cable on the ecu a usb or serial? If its a serial, its exactly the same thing as having a consult adapter connected to your consult port, and never connect a consult cable to your car. If its a usb, then the consult port is installed on channel A. You need to find out what com port windows has stuck this on and make sure its on a usable port. See the Quick Start Guide for details.
calum@calumsult.com
Calum is online now   Reply With Quote
Old 01-08-2008, 09:25 PM   #6 (permalink)
Born2Ride
SE-R on a budget
I have the basic ecu with serial.I have a serial cable for it.Do I just download calumsult and plug laptop to ecu and monitor from there.Whats my best option?
