Old 02-28-2008, 06:31 AM   #1 (permalink)
Nissan Primera p11 throttle body modi !!
I owe a nissan primera p11 1.6 lt and I'm thinking to upgrade / tune the throttle body. I'm thinking of a nissan 2.4lt altima throttle body (cable throttle) but I'm not sure whether it will do, due to the throttle position sensor compatibility with my qg16 engine that I have.
What should I pay attention to ?
Nissan throttle body codes ?
Any ideas ?
Thanks
Nippon is offline   Reply With Quote
Old 02-28-2008, 03:33 PM   #2 (permalink)
sr20
i think, you will see no gains of this mod.
››› My Sunny 2.0 GTi JWT S4 cams - HotShot CAI - Calum Basic ECU
jagy is offline   Reply With Quote
Old 02-29-2008, 04:16 PM   #3 (permalink)
I'm affraid to disappoint you but a friend that put q qr25 throttle body to his almera N16 had a very very noticeable difference. I was in the car before and after the installation and the car was much quicker. Besides, even if you really think about it, there is more air coming in = more gas = more power.
Old 02-29-2008, 06:35 PM   #4 (permalink)
Broke Ass
jer_760's Avatar
I have doubts about that. What was the size difference between the two, just out of curiosity?
95 200sx
sr20ve
Old 03-03-2008, 04:23 AM   #5 (permalink)
I think it was of the order of 1 cm, but I might be wrong on that. I mean 1cm in diameter.
Old 03-04-2008, 12:36 AM   #6 (permalink)
Auto Pilot
Matty Moto's Avatar
Trader Rating: 13 (93%)
Your talking serious mods to get the value of this unit, in my opinion.
Start with a big turbo, them work backwards, not with the intake size.
It really doesn't matter that much, unle$$ you are dead $eriou$ about the re$t of the build.
Messing with the heads via compression, valve and sleeve size nets power, if you use a machine shop with a torque plate, to squeeze your head during the machining. Now you're into major block upgrades, to flow this thing.
Great mod, for an alcohol injected fire breathing dragon, but you'll need a fat exhaust. you'll run out of injector before you get anything worth bragging about from this.
Not for street mods.
No gains, yields nothing but slight throttle response improvement.
Unless it's free and you have a programmable ECU, and a fat exhaust, don't wast your money.
Intake really doesn't matter that much. Neither does porting the heads.
Big valves, cams, springs and compression, now that's different. Now you need this unit.
Buy headers and get an air intake and call it a day, (or go $turbo$)
Good luck.
Matty Moto
92' SE-R "The Red Barron"
92' SE Grocery Get'r
Matty Moto is offline   Reply With Quote
