Old 04-06-2008, 07:52 PM   #1 (permalink)
avanir install ecu question
Installed a W10 Avanir into a '95 200sx SE-R today and the ecu that came with it has a different plug than the JWT ECU that is in it. What can I use to run this engine? ESER5-NMU10 is the part number from the current ECU, but I'm sure that is set for stock DE injectors.
200SXDRIVER is offline   Reply With Quote
Old 05-22-2008, 10:34 PM   #2 (permalink)
_______
Mike's Avatar
Trader Rating: 56 (100%)
More info needed.
Mike is offline   Reply With Quote
Old 05-24-2008, 12:32 AM   #3 (permalink)
VVL goodness Bitches!!!
i think ur trying to use a obd 1 ecu on a obd 2 car ... which engine harness u using the b14 harness or the jdm harness?
All Motor Goodness Bitches!!!!!
'96 200sx SE-R N1 Version 1
PS3 TAG - Miami4ThatAss
C.O.D. 4 All Day Come Get Some!!!
PR N1OF2 is offline   Reply With Quote
Old 05-24-2008, 12:03 PM   #4 (permalink)
VE powered on 12/9/07 :-)
NismoSER's Avatar
Trader Rating: 16 (100%)
That W10 ECu won't plug and play directly into your B14.
Chris
'91 VVL-powered SE-R
'04 G35 6MT
'99 CBR600 F4
