Old 04-06-2008, 10:13 PM   #1 (permalink)
slammedout08
NEED HELP VERY BADLY.. NO SPARK!!!
Hey guys im new on here.. I know this is mainly for SR20's but I have a 1995 200sx se.. And of coarse it has the ga16de.. I bought it for 100 bucks from an older guy who bought a new car.. A cam froze up and caused alot of damage.. So I got a new engine.. I know its good.. I got it in and when trying to start it ABSOLUTLY NO FIRE what so ever.. Nothing.. So I got a new ECU.. STill same problem.. Changed the distributor.. Still same problem Any advice would help.. Thanks
slammedout08 is offline   Reply With Quote
Old 04-07-2008, 11:36 PM   #2 (permalink)
slammedout08
Or can some tell me where I can go to find this awnser.. Please.. Im literally carless waiting for any tips or advice.. thanks
Old 04-07-2008, 11:50 PM   #3 (permalink)
BahamasSR20
boostin feels better than
check plugs that plugin diistributor and check all fuses cause i hade the same problem check coil wires and harness manily harness and contections
lovin boost strong
BahamasSR20 is online now   Reply With Quote
Old 04-08-2008, 04:42 PM   #4 (permalink)
slammedout08
I also forgot to add that.. The idiot before hooked the battery up backwards.. What did it toast? Any ideas
Old 04-08-2008, 04:54 PM   #5 (permalink)
GT2876RBLUBIRD
check for fuel, check for spark
GT2876RBLUBIRD is offline   Reply With Quote
Old 04-08-2008, 06:33 PM   #6 (permalink)
slammedout08
I did.. Theres nothing at all.. I can grab it.. Its completly sparkless.. No fire at all
Old 04-09-2008, 08:54 PM   #7 (permalink)
jer_760
Broke Ass
jer_760's Avatar
Did you check fuses in the engine bay?
95 200sx
sr20ve
Old 04-09-2008, 09:15 PM   #8 (permalink)
budgetNX
SR20DEEEEEP
does it turn over?
http://www.myspace.com/beat_a_bitch
Originally Posted by Shawn B View Post
Then you get pissy, belligerant, and your panties get bunched up when someone, namely me, tries to actually help you with a couple of links?!?
Are you f*cking kidding me?!?
You sir, are an unmitigated selfish, egocentric, self-absorbed, DOUCHEBAG and can go f*ck yourself.
Old 04-10-2008, 11:49 AM   #9 (permalink)
slammedout08
It turns over but there is no spark at all.. I checked and tested all fuses.. They are all good
Old 04-10-2008, 12:03 PM   #10 (permalink)
budgetNX
SR20DEEEEEP
start at the plugs and go backwards.
Old 05-13-2008, 06:58 PM   #11 (permalink)
p10det
when crnking does the dist rotor spin?
what wireing diag have you done?
wireing diagram nd some knowladge can find any problem.
is it just spark cut are is their no injector pulse as well? check all this and confirm each thn you will be able to find the problem.
one more thing is i have seen some one 3 years ago plig the crank sencor conector into something else on a ga16de and he had a simular issue when he changed engine.
good luck
p10det is offline   Reply With Quote
