Old 04-14-2008, 03:17 AM   #1 (permalink)
topdog781
SE-ROLGIST
How do I lean out a JWT ECU.
Everyone claims that the Jwt ecu runs a little rich. Is there a way to lean it out without the use of a (s-afc) for example? IF I lower the feul pressure will that work or will it not work to lean it out? LMK what you guys think is it a good or a bad idea?
"I am the representative for the people"
topdog781 is offline   Reply With Quote
Old 04-14-2008, 09:21 AM   #2 (permalink)
GT2876RBLUBIRD
without some sort of wideband to really monitor your air fuel ratios, i wouldnt apptempt it, a safc is going to act as a piggyback on the ecu to adjust the ratios...if you have a piggyback and wideb and i dont think its a BAD idea, however if you dont have awideband to monitor your exact air fuel ratios you obviously could blow up your motor
GT2876RBLUBIRD is offline   Reply With Quote
Old 04-14-2008, 11:37 PM   #3 (permalink)
t bags
agent camel toe
u cant tune without a wideband..some have tried but its a guessing game.someone i MA has to have a wideband..unless ur willing to take a 3-4hr trip to jersey..pm Fred he will be able to tune ur car at his shop
new b14det vid
http://smg.photobucket.com/albums/v2...t=df8e39f6.pbr
R.I.P. RESPECT SR.
93 p10--spun bearing--jdm swap she lives 06-01-07
96 b14--project ve+t
89 formula--454 swap 12.31 with no brakes
Old 04-16-2008, 01:20 AM   #4 (permalink)
topdog781
SE-ROLGIST
I know someone did this, this forum has been around since 2000.
Old 04-16-2008, 04:38 PM   #5 (permalink)
daveracer
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 88 (100%)
A JWT ECU shouldn't run rich. If your car is running rich, you have other problems. I've ran many many programs from JWT and they were all pretty much on target.
I have a feeling most people run their turbo cars with boost/vaccum leaks by using sh*tty worm clamps with piping w/o bead rolls. Remember, t-bolts and beaded pipes ONLY.
Old 04-17-2008, 04:00 PM   #6 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
JWT runs rich, been shown many many times, when I say rich I mean 10 or 10.5:1 rich. When I was on the dyno I had to take out 2psi of fuel pressure at the regulator to get a nice 11.8:1 at WOT and better fueling when cruising. Car ran perfect that way.
Brent
Old 04-17-2008, 10:10 PM   #7 (permalink)
topdog781
SE-ROLGIST
Brent
That's what I like to hear coach . Anyone else has had good or bad expirience by doing this?.
Old 04-17-2008, 10:55 PM   #8 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
If you don't do it on a dyno or with a wideband you could have a really bad experience.
Old 04-18-2008, 12:57 AM   #9 (permalink)
spdracerUT
sleeper
Mine ran 11.4-11.7, but I guess your results may vary. You can reduce the fuel pressure and the ecu should compensate during light load when it's running closed loop. But I wouldn't try it without a wideband hooked up.
Khiem
'05 Evo
'05 CBR 600RR
Old 04-18-2008, 08:56 PM   #10 (permalink)
jonwepa
Going on motor #3......
Trader Rating: 24 (100%)
Brent
Agreed, mine was around 11 to off the charts as it went towards redline and never went above 12 . It really killed my hp #'s
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25....
New set-up: same car, but with a gti-r motor and a gt28r. New LOWER times coming soon!
jonwepa is offline   Reply With Quote
Old 04-20-2008, 09:23 AM   #11 (permalink)
topdog781
SE-ROLGIST
This question was geared toward an N/a motor maybe it's different. Seems like the turbo guys are saying they are getting bad results.
Old 06-13-2008, 04:14 AM   #12 (permalink)
gtswrx
Trader Rating: 18 (100%)
If N/A just make sure to clean your Air Filter often and have decent spark plugs at all times, then it should run nice A/F ratio...
Still you must understand JWT does not have a magic ball to make a program so exact as to perfectly match what you have in your car. Wideband and dyno is the only way to suit a program exactly to your engine.
Loading...
gtswrx is offline   Reply With Quote
