Old 06-03-2008, 11:37 AM   #1 (permalink)
Raggy
on 7th day God made SR20
Extruded Honed Extractor?
What exactly is meant by 'extruded honed'?
I have a sr20ve stock header and was told that if i get it extruded honed it would suffice as a performance or (close to) header.
How is it done and what gains can i expect?
tanx
2000 Sr20ve Powered Pulsar VZ-R
SR16ve Cams & Ecu, Greddy Emanage (Blue), Apexi RSM (SCD), 60mm Exhaust, JWT Pop Charger Air filter, Tein HA coilovers, 15" Wheels, ACT 6 Pad Sprung Center Clutch w/ Heavy Duty P/Plate, Prothane Motor Mounts. 175whp, 134ft-lb Torque, Top speed 140mph (so far) To come: Noise!
Raggy is offline   Reply With Quote
Old 06-04-2008, 11:13 AM   #2 (permalink)
1fastser
BIG-NUTTED Classic
http://www.extrudehone.com/afmpro.html
Extrude honing is an internal polishing process that uses an abrasive 'puddy' material. When forced thru the part, it smoothes/polishes the inside...for example, an extrude honed exhaust manifold would have had the puddy material forced thru the runners and the end result would be very smooth on the inside resulting in less drag and more efficiency.
Jody
*DONE!*
The Beast.
