Old 06-05-2008, 02:11 AM   #1 (permalink)
SR dubbed RX8
Question maf or map on emanage
so can i change the maf for a map sensor with my emanage blue? i have a s13 sr20det and i want to do away with the maf and replace it with a map, can this work or do i need a differant managment sys.?
Everyone has a reason for doing things, some of us just dont know what it is till we do it.
2004 sr20 powered Rx8
95 Honda Accord. (beeter)
cmr333 is offline   Reply With Quote
Old 06-16-2008, 07:41 PM   #2 (permalink)
i do not think blue has any option ports
p10det is offline   Reply With Quote
Old 07-02-2008, 12:09 AM   #3 (permalink)
The blue has the pressure sensor option, ignition harness option, sub-injector harness option.
The pressure sensor option references boost to cross over to different fuel-maps (I think) i have no personal experience with this. Find Blue Emanage Manual.
They sell it, and I know the software has two seperate fuel-map areas, one for maf and one for map.
I think you can set it up as follows - maf up to preset maf voltage point, cross over to map sensor fuel-map?? I think??
Sorry.
I have blue with ignition harness, i control injectors, maf signal, and timing.
The Money Pit is offline   Reply With Quote
Old 07-02-2008, 08:27 PM   #4 (permalink)
SR dubbed RX8
yeah i found out that im stuck with the maf for now till i get a stand alone setup...ill just enjoy having the blue and my eo1 to play with.
