Alright my bad guys, been MIA for a couple weeks. Just in case anyone wants location of where the map sensor and ait sensor should be mounted here you go.
This is the AIT sensor location on the ic pipe right before the TB.
This is the MAP sensor location. I had a 1/8th inch pipe thread coming off the bacof the intake that had been tapped. Teflon taped the threads put a gender changer on the pipe so I could thread the map onto it.
Now, This was the original way I did this and later found out when installing the BOV that it said you needed to get vaccum from somewhere post the TB so I put a T in and have the MAP and a barbed fitting for the BOV hose feed line. Is the T the right way or. Will it cause innaccurate readings with re MAP?
Here are a few more pics. I actually made a wiring harness for the MAP and AIT sensor to splice into the harness in the car.
Hope it helps.
PT
