nooob:maf delete????help please - SR20 Forum
Old 02-23-2010, 07:53 AM   #1 (permalink)
Question nooob:maf delete????help please
I just got a 92 nx2000 with an sr20 det. i was wondering if i could get a tune that deletes the mass air flow censor so i can use a blow off valve?
nismo2000 is offline   Reply With Quote
Old 02-23-2010, 07:59 AM   #2 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Not with any of the current plug & play ECU solutions available, though you could run a blowthrough MAF setup, and VTA.
Old 02-23-2010, 11:49 AM   #3 (permalink)
what is VTA?
Old 02-23-2010, 11:58 AM   #4 (permalink)
Feedback Score: 5 reviews
vent to atmosphere....
I see cars on here everyday that aren't even running blow through that are vta. My car runs like ass any time there is a leak so I don't know how they do it.
Old 02-23-2010, 12:58 PM   #5 (permalink)
does any one know what all i need and where i can get it?
Old 02-23-2010, 01:06 PM   #6 (permalink)
chriscar's Avatar
I'll bet you that most of them run like ass.
Old 02-23-2010, 01:11 PM   #7 (permalink)
chriscar's Avatar
All you need to do is put the maf between the cold side of the intercooler and the throttle body. Search on blow through for more details.
Old 02-23-2010, 01:17 PM   #8 (permalink)
so your saying if i run vta and blow through the car will run like sh*t?
Old 02-23-2010, 01:20 PM   #9 (permalink)
chriscar's Avatar
No, if you want to VTA, then you need to run blowthrough, otherwise it'll most likely run like sh*t.
Old 02-23-2010, 01:33 PM   #10 (permalink)
yaaa now i understand,but now is blowthrough a type of maf or tune or what?
haha srry like i said im a newb.
Old 02-23-2010, 03:34 PM   #11 (permalink)
Kicking it over @ g20.net
blowthrough is blowing the air past the maf, a draw through setup draws/pulls the air pass the MAF,,,,,IIRC
enohand is offline   Reply With Quote
Old 02-23-2010, 03:50 PM   #12 (permalink)
Nissan Tuner
Put the maf (or map) or whatever it is you are using to measure air right in front of the throttle body so that is the last thing the air will encounter before going into intake. You don't want to let unmeasured air into your motor, especially if you are boosting.
A map is a Mass air Pressure sensor. It reads the air pressure inside the intake tube. It's alternate to a maf but you need an ECU that can read it.
First car: '90 240sx SE (stock) (still own)
Second car: '92 Honda Accord (2.5" exhaust) (5 mph flip into ditch trying to powerslide in gravel ; Junkyard)
Third car: '98 240sx SE (stock) (still own)
Fourth car: '01 Sentra SE (Stage 3 clutch, AEM air filter, Energy Suspension engine/tranny mounts)
Brian47590 is offline   Reply With Quote
Old 02-23-2010, 04:15 PM   #13 (permalink)
chriscar's Avatar
You ideally want the maf in a straight path of air, as far away from bends as possible. On a B chassis car that would be after the cold side intercooler bend, and before the 90* bend into the throttle body.
Old 03-07-2010, 11:22 PM   #14 (permalink)
I've read about systems that run off just the tachometer and a throttle position sensor, the idea being that you can guesstimate the amount of air coming in, and add a bit of extra petrol to err on the side of caution...
I know that these aren't very practical for road (change altitude and the ambient pressure changes, and your guesstimate gets shot), and I guess the same would be true for changing gears with a blow off...
Chriscar is that why you discounted it, or are these systems not commonly available over there? Not trying to be smart or anything, just curious...
mongoose007 is offline   Reply With Quote
Old 03-08-2010, 08:40 AM   #15 (permalink)
chriscar's Avatar
^Sounds like you're talking about a complete aftermarket ecu solution.
Old 03-08-2010, 11:28 AM   #16 (permalink)
going thru life @ 1 bar
Feedback Score: 21 reviews
Im running draw thru on mine, but my BOV is recirculated
...Currently down due to a clutch disc spring failure....
Old 03-11-2010, 10:38 AM   #17 (permalink)
your talking about a speed density setup old school efi systems used...
can a stock Nissan draw through maf handle a boosted blow through setup? seems there's alot more to it than all of that I dunno.
You can get a mafia which converts a MAP sensor signal to a maf signlal to run with your stock ecu...
1990 pulsar GTiR RB. reving to 4k at 60MPH in 5th gear
I <3 85 to 95 JDM!
ZED_not_zee is offline   Reply With Quote
Old 12-11-2011, 02:47 PM   #18 (permalink)
lol wow i *** came here to learn how to vent... this stuff is retarded i miss my hondas.. nissans seem to be averbuilt like german cars
se-R-T is offline   Reply With Quote
Old 12-20-2011, 08:18 AM   #19 (permalink)
TunerCode
MAF to MAP conversion will be available in the new SA version of TunerCode, available hopefully late spring, early summer next year. (List of Features)
Dave
dfddfd2 is offline   Reply With Quote
Old 12-20-2011, 10:35 AM   #20 (permalink)
awesome
