S13 SR20DET swap, firing only on cylinder 1 - SR20 Forum
Old 11-15-2010, 07:17 PM   #1 (permalink)
Hello all,
Just installed my S13 SR20DET Blacktop in my 240 and it starts up and will not idle. I checked for firing on the cylinders and I am only getting fire in cylinder 1. 2,3 and 4 are getting no fire. I bought a harness from Enjunku and installed with the engine.
Any help would be greatly appreciated
240turbotim is offline   Reply With Quote
Old 11-15-2010, 07:35 PM   #2 (permalink)
Parting out my car
Feedback Score: 25 reviews
damn dude that sucks. check the plug wires? How did you check for fire? Check for spark, check that injectors are clickin'??
Slow is the new fast
Old 06-16-2011, 03:02 AM   #3 (permalink)
ecu??
ecu i had a auto ecu which caused only cylinder 1 to fire
DREX007 is offline   Reply With Quote
Old 06-16-2011, 03:12 AM   #4 (permalink)
Lurker
Yeah check your plug wires....make sure you've got them on the distributor correctly and that they're not all switched around.
NelsonPeeTen is offline   Reply With Quote
Old 07-07-2011, 01:00 PM   #5 (permalink)
Professor Dingbat
Feedback Score: 14 reviews
Are you running coil on plug or a distributor? IIRC the USDM ECU is set up to run a distributor (with 1 coil wire) while the Silvia ECU sends 4 seperate signals to 4 coil packs.
