95 B14 SE-R: OBD1 or OBD2??? - SR20 Forum
Old 06-09-2011, 08:25 AM   #1 (permalink)
Hi guys,
I've tried doing a search (on both forums) and could only find old threads on the subject and no definitive answers. I've got an early VIN 95 B14 SE-R MT and would like to switch to a G20 MT ECU to get rid of the speed limiter and raise the rev limiter, but all 94-96 G20 ECUs seem to be OBD2. I've always believed my car to be OBD1 - I have both OBD1 and OBD2 ports (one under the dash and one next to the fuse box) and have always used the port next to the fuse box (this is the OBD1 port, right?) whenever I've pulled fault codes on a CONSULT.
I guess first question is... Is my car OBD1 or OBD2?
Second question is... Can I install a 94-96 OBD2 G20 MT ecu in my car?
Thanks for your help.
Davin
davin550
1995 200SX SE-R; 5MT; no sunroof
Hyperco's w/ AGX struts; Suspension Techniques Rear Sway Bar; Stillen FSTB; Ebay RSTB
Place Racing Cold Air Intake; B&M Short Shifter; Ultra Wires with indexed plugs; JWT S3 Cams; JWT ECU
davin550 is offline   Reply With Quote
Old 06-09-2011, 11:00 AM   #2 (permalink)
SR20 apprentice
Feedback Score: 16 reviews
1. OBDII
2. Yes
Tommy's 98 SE
Old 06-09-2011, 11:32 AM   #3 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
Tommy is correct, all B14s are OBD2. Because TN only does the OBD2 test on '96 + cars, you get by on the loop hole and only need the sniffer test. This can be a good thing/bad thing depending on how clean your car is. My B14 doesn't have EGR because of the VE, but passes the OBD test. All of the B14s have both the OBD2 plug under the dash and the Consult plug under the fusebox.
The community is here.
Old 06-09-2011, 11:51 AM   #4 (permalink)
hey all,m don't want to hijack your post but hummm
I have a B14 Se-R and want to put a B13 GA16DE Ecu in it to make the convertion from obd2 to obd1
but, can I use the stock GA16DE or absolutelly need to be chipped?
Icitte is offline   Reply With Quote
Old 06-09-2011, 12:19 PM   #5 (permalink)
Eric - Wow, so will a VE pass TN sniffer test without any issues? Did you have to do any special to get it to pass? Are there any other locals running VE that did not have any problem passing? If it passes without a hitch, I may need to re-think my strategy.
Old 06-09-2011, 01:15 PM   #6 (permalink)
eric96ser's Avatar
My B14 is a '96, so I go through the OBD test and not the sniffer.
Old 06-09-2011, 01:16 PM   #7 (permalink)
eric96ser's Avatar
Won't work.
Old 01-21-2012, 05:28 AM   #8 (permalink)
JordanWhiteMusic.com
Def won't work, I wonder if the motor would even start up.
Jordan
'91 SE-R
'93 SE-R
www.jordanwhitemusic.com
Storm88000 is offline   Reply With Quote
