help please aem ems 2 - SR20 Forum
Old 11-04-2011, 12:40 AM   #1 (permalink)
alright i have everything installed but im afraid to start up because it tells me to download the closest base calibration from their base maps available but the ones they have are map based and i am running a maf with not map sensor or ait sensor what do i do?
selfbuilts13 is offline   Reply With Quote
Old 11-04-2011, 01:33 AM   #2 (permalink)
also
also can anyone tell me where i will need to put the map sensor and the IAT sensor if i get them.
Old 11-07-2011, 04:34 PM   #3 (permalink)
thanks for all the help guys hahahaha NOT
Old 11-07-2011, 11:56 PM   #4 (permalink)
Ruby Red SE-R
Feedback Score: 4 reviews
Dude you can calibrate the arm to run with all your stock sensors maf etc
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 11-08-2011, 09:07 PM   #5 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
They have MAF based startup calibrations, you need to look again in the list.
Brent
1999 SE-L -- back to NA form
Old 11-08-2011, 11:48 PM   #6 (permalink)
Comps B13
did you install the CAS disk??
92 red SE-R
Silversentra92 is offline   Reply With Quote
Old 11-08-2011, 11:57 PM   #7 (permalink)
Tired!
coach's Avatar
You don't need to with the standard FWD distributor, seems to be an issue more with the RWD. I have done 4 AEM EMS installs and never swapped out for the AEM CAS.
Brent
