hydrocarbon buildup / bad gas mileage&emissions? - SR20 Forum
Old 01-31-2012, 02:59 PM   #1 (permalink)
Just took my car to get emissions done, it passed but the mechanic said barely because of the hydrocarbon buildup? he said I should be getting way better gas mileage and it can also caise dramatic loss in power. What do I do??
xkyxlxex is offline   Reply With Quote
Old 02-28-2012, 03:16 PM   #2 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
Check your timing/fuel pressure/O2 sensors. My bet is you could run some premium and up the timing to about 17* and solve a lot of that.
Brent
1999 SE-L -- back to NA form
Old 02-28-2012, 05:25 PM   #3 (permalink)
I had the same kind of issue. It was hyrdo-carbon build up in the intake runners. Not cheap to clean out if you pay some cheap but a PITA to do you self but you could always do some thermoblock spacer at the same time to make the work more worthwhile.
Start with coaches suggestion first though.
coors75 is offline   Reply With Quote
