bump, make offers...
Sr20vet cams - $550
JE custom dish top Pistons - 8.5:1, 86.5mm bore, copied sr16ve piston valve reliefs - $450
Eagle h-beam rods, w/ arp rod bolts - $250
46mm Tial wastegate - $350
Hks racing bypass valve, blue spring - $100
Xs engineering 20x11x3 silvia intercooler (
http://www.xs-engineering.com/xsstor...&idproduct=615) - $350
b14 Jwt ecu – any program - $400
Crane HI-6 CD ignition box, LX92 external coil, modified distributor off a 99 sentra se - $300
Zeitronix wideband complete with LCD display, egt probe, boost sensor - $400
Arp mainstuds - $80
3” mandrel bent exhaust, hollowed out magnaflow 3” high flow catalytic convertor, magnaflow 3” muffler, dynomax 3” bullet resonator - $350
Vis carbon fiber trunk, top needs to be buffed out - $350 local pickup only
