**oops, just realized i said a sentra partout. only the parts listed below are for sale. sorry for the confusion. **
46mm Tial wastegate - $350
Hks racing bypass valve, blue spring - $100
Xs engineering 20x11x3 silvia intercooler (
http://www.xs-engineering.com/xsstor...&idproduct=615) - $350
Arp mainstuds - $80
3” mandrel bent exhaust, hollowed out magnaflow 3” high flow catalytic convertor, magnaflow 3” muffler, dynomax 3” bullet resonator - $350
Vis carbon fiber trunk, top needs to be buffed out - $350 local pickup only
Sr16ve head w/o cams, includes 333cc injectors, sr16ve maf, distributor, thermoblock spacers - sold
Sr20vet cams - sold
Garrett dual bb Gt30r turbo, .82 a/r exhaust housing, 4 bolt - sold
Protech equal length turbo manifold and downpipe, 4bolt to v-band adapter - sold
JE custom dish top Pistons - 8.5:1, 86.5mm bore, copied sr16ve piston valve reliefs - sold
Eagle h-beam rods, w/ arp rod bolts - sold
Jwt ecu – any program - sold
Crane HI-6 CD ignition box, LX92 external coil, modified distributor off a 99 sentra se - sold
Jwt z32 pop filter - sold
Nismo 740cc injectors - sold
Nismo FPR - sold
Z32 maf w/ pigtail - sold
Greddy boost controller - sold
Custom 2”-2.5” hotside, 2.5” coldside piping w/ t-bolt clamps, and blue silicone hoses - sold
949racing Nickel finish 15x8 6ul rims with azenis sport 205/50/15 tires, 8 aluminum valves, 36 offset, (
http://www.949racing.com/index.asp?P...PROD&ProdID=10) - sold
Greddy MSS - sold
Ve Oil pump kit (crank pulley, spacer, front cover, oil pickup) - sold
Arp headstuds - sold
Walbro 255lph fuel pump - sold
Used Act 4 puck clutch disc & act heavy duty pressure plate - sold
Clutchnet lightened aluminum flywheel - sold
10" pusher/puller Slim Fans - sold
JDM crystal clear Headlights w/ harness - sold
oBo, Shipping and paypal fees not included. Located in San Diego, 92129
