new design gearbox strenghtening collar - SR20 Forum
Go Back   SR20 Forum > Classifieds > Forced Induction Performance Parts
Old 11-13-2011, 02:23 PM   #1 (permalink)
Here is the latest version of my gearbox strengthening collar. It has taken a while and slowed down my rebuild but it is ready now. There are many bits involved and companies are not very fast when doing small batches ,especially prototypes.
The collar is based on my previous one, but as some members showed concerns on how it would help with the case being broken by the final drive pushing on the case, I modified it and many parts have been added.
The brace fits with no mods , no clearance issues with the chassis and can even be fitted without welding it to the case as the brace is very very well shaped with minimal clearance. This means it can even be fitted without dropping the engine and box, you will just need to lower it a little bit.
The plate is secured by 4x10mm 10.9 studs to the bottom of the casing. To do so we have realized some simple but special steel screws : male side is 8x1,25 , female side is 10x1. These have been machined with high grade steel.
A set of 4 alloy (6061)spacers are supplied and are used to correctly space the collar.
As you can see a portion of the collar is skimmed. This is needed to clear the chassis, but it is still 10mm thick, so strength is not a concern.
To finally stop the pressure caused by the final drive on the case there is a 15mm top cover, correctly shaped and spaced and two 10mm thick alloy discs that fit just over the bearings location. The alloy discs can be adjusted by 8mm Allen screws and then secured by bolts. In that way the pressure exerted by the discs is completely adjustable as you don’t want too much force to be applied there.
Each disc has 4 screws on it, so pressure can be evenly distributed.(not pictured)
I think this is as far as we can go with the std case. I know that some people will complain that the other portion of the case will now receive all the pressure, but I doubt there is something that can be done there, and I think the brace will really help a lot.
Considering that a friend’s car has done many passes on the std collar and over 400bhp without failure, I am confident this new version will give even better results.
All the parts are precisely cut and machined from high grade alloy and steel for a hassle free installation and performance.
Depending on the interest kit can be realized in small batches. Price will be $500 + shipping.
Please note that the kits will be made to order, with a lead time of around 2 weeks and a deposit is needed before starting production.
For more details, please e.mail as i am not very often here.
str_motorsport is offline   Reply With Quote
Old 11-13-2011, 02:24 PM   #2 (permalink)
Please e-mail to
str_motorsport@hotmail.com
Old 11-13-2011, 02:25 PM   #3 (permalink)
Uploaded with ImageShack.us
Old 11-13-2011, 02:26 PM   #4 (permalink)
Old 11-13-2011, 02:27 PM   #5 (permalink)
Old 11-13-2011, 02:28 PM   #6 (permalink)
Old 11-13-2011, 03:04 PM   #7 (permalink)
Shipping to USA by EMS is $75
Old 11-13-2011, 11:17 PM   #8 (permalink)
Ruby Red SE-R
Feedback Score: 4 reviews
What kinda tranny is that pictured with 2 mounts on there? Also will this setup fit the USDM B13 SE-R trannys?
Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell View Post
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI View Post
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
scrildo is offline   Reply With Quote
Old 11-14-2011, 12:35 AM   #9 (permalink)
That is a pulsar gtir awd tranny.
Sorry it will only fit thread gtir awd tranny
Old 11-14-2011, 06:16 AM   #10 (permalink)
so with this in place the stock tranny should take a little more abuse ? if so will be in touch with u about getting one
sss-gti-r is offline   Reply With Quote
Old 11-14-2011, 06:44 AM   #11 (permalink)
The stock casing is a bit weak,and when launching or running Hi boost,it can break damaging the gearset too.
The damage is caused by the forces that try to separate the shafts and the final drive pusching on the case.
The collar surrounds the bearings locations so they cannot move and the top cover avoids the final drive from driling a hole in the case.
This is the only way to add strenght to the case and the best engineered collar ever made
Old 11-14-2011, 01:21 PM   #12 (permalink)
Pm replied
Old 11-18-2011, 02:29 AM   #13 (permalink)
GB ends on Monday,please hurry up if you are after one
Old 11-18-2011, 07:54 AM   #14 (permalink)
nice!!
RalliartRsX is offline   Reply With Quote
Old 11-21-2011, 03:37 PM   #15 (permalink)
Gb ends today
Old 11-23-2011, 12:28 AM   #16 (permalink)
Now closed
Old 11-23-2011, 10:55 AM   #17 (permalink)
70/30 Racing
Rockwood's Avatar
Awesome piece.
MotoIQ Project G20:
Old 11-24-2011, 11:17 AM   #18 (permalink)
fu*k i missed it now got the downpayment money get back to me let me know if u can have a next one made also
Old 11-27-2011, 01:42 PM   #19 (permalink)
hey tell me something what type of oil do u guys use in your gearbox and would a twin disc clutch help also
Old 02-08-2012, 12:56 AM   #20 (permalink)
Guys I. Am running another GB.
Please join if interested
