Hi Greg,
how much for the bottom window molding on a b13/94 sentra se-r? I need the molding that "elbows" around the bottom rear of the driver's side window. The elbow part of the molding is missing on my car, and since that gap is right above my door latch, it's allowing rainwater to rust my latch out. I had to get a locksmith to open my door a few days ago
also, do you have the spacers in stock for the VVL Aluminum crank pulley? What parts would I need to buy to use the Mossy crank/water pump pulleys on my DE (including belts)?
Thanks,
Jeremy
