Top 10.
Battery drill
Eastwing 22oz claw hammer
Mig welder
Angle Grinder
1/4", 3/8", 1/2" sockets, power bar, pipe, spanners, screwdrivers etc.
Top 10 useless tools:
EZ out
Glass cutter with small diameter wheel
Anything not metric, i.e. measuring devices, spanners, sockets, bolts.
Brace & bit
Chinese adjustable spanner where the jaws do not meet parallel
Chinese vice grips where the pressed female thread section is not welded to gether
$3 40 piece socket sets
Carpenters hammer with a tubular steel shaft
A 150W 6" bench grinder
A stand for converting a hand drill to a bench press
White '92 NX2000 All Stock.
Impact Swivels, Impact Gun, Air Compressor, Dremel, Vacum Bleeder, And the 2 way wrachet Wrenches, $3 40 piece Socket Sets i go trough atleast one of those a weekend (all i seem to lose are the 13mm 15mm and 17mm) but it's better than loosing my Snap-ons.
2.2L (all bore) SR20DET crower rods, JE pistons
80lb Injectors, A1000 Fuel Pump & Pressure Regulator
Greddy Manifold, FAST 90mm TB,
Fully Built Head C3 intake/S5 Exhaust Cam
AEM EMS
EQ Manifold T4 Flange, Tial Waste Gate/BOV,
Griffin FMIC 3" IC piping
PTC PT67GTQ TURBO
some of the tools that i use to work on my car or if my friends come over to work on there cars.
not in any particular order:
1. screwdrivers
2. vise grips
3. hammer
4. sockets & ratchets
5. pry bars
6. gear wrenchs
7. jack & jack stands
8. drain pan
9. case of heineken
10. a lot of chicken for the bbq
soon to be my engine hoist and stand, dremel, my entire craftsman tool set, the microwave and fridge in the garage, and the retarded amount of rolling rock in that fridge
If you can't change your oil, don't mod your f-cking car Coming Soon:
Some unknown project car...bottle fed this time
Late response, but have to chime in. I'm not mentioning sockets & wrenches & stuff, cause those a are a given AFAIC.
0) Garage with ample space. http://xxiii.com/~wcox/garagepix/
1) DeWalt 12V drill. Don't use on the car that often, but probably my favorite all-around tool. Enough ass to run a spade bit through thick wood, and small enough for tight car stereo work. Perfectly balanced over the trigger-finger spot. Beautiful Engineering
2) Metric Tap & Die set. Didn't see this mentioned before. Has saved the day on many a job when threads became problematic. ~$50 @ Sears Hardware.
3) Air Ratchet, 3/8" mini - saves time & bloody knuckles in tight SR20 engine compartments.
4) Air Impact, 1/2" - gotta have to blast off the big stuff.
5) Epoxy Floor - makes everything easier and neater, don't even use my creeper any more, just slip in & out. Speeds clean up.
6) Blasting cabinet - for cleaning up parts.
7) Good lighting, stationary & portable.
8) Hardly a necessity, but damn nice: my DIY powder coating equipment.
Think how cool it would be to be under the car installing, say exhaust or susepnsion and just , "Hey, tool midget, bring me a 22mm open end wrench" and then the little midget hobbles to your tool chest and brings you the wrench.
Think about it, its great work opportunity for midgets who are discriminated against by the normal workforce and we can put them through a little (no pun intended) tool academy so they know their tools. And if you pay extra, you can get a midget that knows his sh*t about cars. They would be trained by giving them magazines to read when you put them back in their cage at night, so they can read sport compact car, turbo, etc etc and be brushed up on all the current stuff so you can have a conversation with them while theyre not handing you tools.
Who wants in ?
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
funny thing about midgets, there was a restraunt downtown that had midgets with huge sombreros that would walk around that had salsa in the middle and on the rim of the hat, chips. i guess other midgets made a stink about it, but the midgets that worked there didnt care because they were getting paid over $20/hr and tips. im not sure if the restraunts open.
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
Id so go to that restaurant all the time.. all the hippie liberal midgets probably screwed that away... just like theyd screw up my tool midget idea...
