Old 03-01-2005, 12:17 PM   #1 (permalink)
Master Cunnilingust
Trader Rating: 37 (100%)
The ultimate home garage design
What's you guys' idea for the ultimate home garage design?
The one I plan to build when I build my house, will be a three car garage, with the third stall partition walled off. The walls will be covered with those acrylic panels like they use in bathrooms so that you can wash them off, and have sealed lens, flood lights recessed in them. There will be a grated floor drain that runs around the entire perimeter of the room, and the the concrete will have radiant heat. All the workbench and tool storage space will be recessed and a large roll type door will be pulled down to isolate them from the rest of the garage when painting or washing a car. It will have it's own furnace, and A/C with a thermal exchanger, so the air is constantly being changed out, and no air is recirculated. There will be both a cold and hot water spigot. There will be a full bath so that I can take a shower if I get really dirty, and an eye wash station. I'm not sure if I'll have a lift or a pit. The pit would be cheaper and safer, and I could install an electric retracting roll type cover that'll handle the weight of a car should someone accidentally drive on it. The pit would have it's own regulated pneumatic air supply, recessed lighting in the walls and floor, and electrical outlets. There would be a beam and electric winch/pulley for pulling motors and trannies out. There would be a tandem garage door setup, or a modified single garage door that would be several inches thick and insulated. That's all I can think of for now.
- Rob
Old 03-01-2005, 12:42 PM   #2 (permalink)
Honda smells > My Nissan
Trader Rating: 0 (50%)
Thats sounds like a sweet mortgage...I mean garage. Quite a plan, hope it happens for you. You might as well add a bed since it doesnt sound like you will ever want to leave the place.
B14 w/ 2 broken motors and no more T25
Sorry I am no longer taking orders for intercooler piping or exhausts.
I miss my car.
crudinyourface is offline   Reply With Quote
Old 03-01-2005, 12:59 PM   #3 (permalink)
Master Cunnilingust
Well, I do construction, so I'd be doing it all myself, so it really won't cost that much more than a regular garage would. The HVAC would be the most expensive part, a few thousand in that and the radiant heat would be part of the radiant heat system that heats the rest of the house.
Old 03-01-2005, 01:26 PM   #4 (permalink)
I need to get a picture of my friends garage. Its not that it has anything really great in it, but its freaking huge. IIRC, it has 5 doors, its two storys high, and you could probably fit close to 10 cars in it.
Old 03-01-2005, 01:40 PM   #5 (permalink)
Big Bossman
Doug_O's Avatar
This was in the off topic section a few months back, and it's just ridiculous.
http://members17.clubphoto.com/scott...30/guest.phtml
Doug
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 03-01-2005, 04:09 PM   #6 (permalink)
Se-r Heavyweight
That quite possibly was the sweetest garage I have ever seen.............sigh I wish I could have one along with the GT3
"Proverbs 5:21
For a man's ways are in full view of the LORD ,
and he examines all his paths."
SerStillen is offline   Reply With Quote
Old 03-01-2005, 05:00 PM   #7 (permalink)
retired
How do/would you keep the pit clean? Do you have to worry about things like fuel dripping in the pit and all that or would it be connected to that drain system? Any plans for a floor coating?
NOT SR20 POWERED
needs.
Old 03-01-2005, 06:53 PM   #8 (permalink)
Southern Boy!
sweetest garage ever.. will u be posting pics of *** like that guy did? i like the idea of a pit.. only problem is that you would have to have stools/step ladders for when u cant reach something and cant lower the vehicle.. and i have the same question as above.. how would u keep that pit clean?
91 G20 Avenir Swap
200sxse-r is offline   Reply With Quote
Old 03-01-2005, 07:13 PM   #9 (permalink)
70/30 Racing
Rockwood's Avatar
that garage was cool, but it wasnt really meant for actually working on your car for anything other than oil changes, etc. the drive on lifts are good for exhaust work and oil changes, but little else because the wheels are still on the ground. the checkerboard won't withstand impact well from dropping sh*t.
pits are alright, but i wouldnt call them safer. i would much rather drive my car on something, align the lifts, and pick the car up than drive it over a 5' deep hole. some work with pits isnt any easier than with some jackstands.
Steve Rockwood
92 G20 - PTD #73
Rockwood is online now   Reply With Quote
Old 03-01-2005, 07:15 PM   #10 (permalink)
Thats not a garage. That is a shop. LOL!
-Rob-
Get ready for a big SE-Rprise
Old 03-01-2005, 07:49 PM   #11 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
Sounds like a plan, just remeber with a lift you need taller ceilings. Other than that, give yourself plenty of room on either side of the car to work in your design. My *shop* area has a 10x10 garage door, that opens into a 25' wide x50' long work space with 12' ceilings. I have enough room to cram 4 cars in there if need be, but really only keep the race car in there and room to work on my daily drivers.
Hers a shot of a 20' section of wall where most of my tools hang. My specality tools are held in three roll chests.
Heres the race car on jack stands with various motors in stages of rebuild.
Things ive learned having this much space....
1) You can never have too many outlets...
2) Have compressed air in multiple locations, celing drop downs are best...
3) You can never have too many lights...
4) Hot water is for pussies...
5) You would be suprised how often I wish I had a dedicated parts cleaner....
6) You can never have enough shelving...
7) PAINT the floor, that checker board stuff looks nice but traps dirt...
8) A shop vac will come in handy more times than you will imagine...
9) Dont forget the stereo...
10) Lastly, dont let your friends know you have the phat setup...or youll be working on cars other than your own...
Old 03-01-2005, 08:58 PM   #12 (permalink)
Now accepting donations!!
El Gabito's Avatar
You should be very careful with the drains and such as well! If you get fluids in there that shouldn't be (nearly everything that comes out of a car) you can get some serious EPA fines. Most new shops don't even have drains anymore. Any spills should be cleaned up immediately in the proper manner, though that can be a pain sometimes. The same rules apply to businesses and residents.
Just an FYI before you go to the trouble.
My real name is Kyle
El Gabito is offline   Reply With Quote
Old 03-02-2005, 07:16 AM   #13 (permalink)
EECS Nerd.
Checking Glenn Nakata's place. Good friend to the Z community and Mike K.
http://www.stillensucks.com/Garage_S...raged_12_2003/
I could eat off that!
BTW, he's single and employed as a programmer I believe, thus the time/money to do this :p
Old 03-02-2005, 11:40 PM   #14 (permalink)
70/30 Racing
Rockwood's Avatar
oh yeah, my new "garage":
10.5' ceilings.
20'x20' for the cars, 11'x30' for the workshop.
most likely a 2 post low lift (will lift high enough to stack cars in there).
i will weld together a bunch of worktables for the workshop, 1/8" steel tops, square tube structure.
coated floors in some sort of urethane 2 part.
4 220v outlets strategically placed around the garage.
3-4 110v outlets per wall.
6 different drop down compressed air ports.
4 speaker stereo wiring.
one of those high powered woodworking vacuums (dust sucks my ass).
and finally a place for all my tools to be out at once (sucks rolling the table saw, drill press, welder, etc into one pile in a corner).
there is another garage for just 2 cars as well.
in addition, the house is a split level house built on a hill, and it has a lot of "basement" space that is currently just dirt. one area, ~15-20'x8' will be converted to the "engine room" and will be used for storage, etc. there will be a removeable hydraulic hoist i will build to transfer heavy items between elevations.
unfortunately, this will be my parent's new house, but i will be able to use it whenever i want, and the SE-R and racecar will be stored there.
Old 03-03-2005, 12:08 AM   #15 (permalink)
El Gabito's Avatar
I was gonna say... Rockwood's ballin!
Old 03-03-2005, 01:09 PM   #16 (permalink)
yeah it's a race car
back to black's Avatar
i plan on making my "garage" out of a barn because then i have plenty of space, big doors, and did i mention plenty of space
Talk is cheap
But doing it is expensive
back to black is offline   Reply With Quote
Old 03-03-2005, 04:25 PM   #17 (permalink)
Master Cunnilingust
I was thinking that in addition to air outlets that I could put a retractable reel on a swing arm overhead that allows you to move the reel in an arc, so that you can keep the hose off of the car. Sort of like what they have at car washes. This would be nice when doing painting.
Old 03-03-2005, 09:11 PM   #18 (permalink)
owned by SE-Rs!
Man Id love to have a heated garage. That is my ULTIMATE garage.
93 Sentra SE-R
Work in Progress
Old 03-04-2005, 07:30 PM   #19 (permalink)
70/30 Racing
Rockwood's Avatar
yup, that's exactly what we did...
Old 03-08-2005, 03:14 PM   #20 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
I think I need to hang out in your garage! I have a ton of space, but no heat or insulation on the walls and lighting sucks MAJOR! So, that leaves me to work on warm weekends or spring/summer. I really like the garages posted here. One day I hope to have one similar.
brent
