Old 05-17-2005, 10:13 PM   #21 (permalink)
I can get you a nice bead roller for $100 or you can sign up on turboforum.net theres a guy on there that sells them.
91sentragtir is offline   Reply With Quote
Old 05-18-2005, 11:53 AM   #22 (permalink)
Do you knows the guy name?
fllwyb is offline   Reply With Quote
Old 05-18-2005, 02:24 PM   #23 (permalink)
no but if you sign up there u can do a search for "intercooler piping bead roller"
Old 05-28-2005, 09:40 AM   #24 (permalink)
Making the G breathe hard
Jaketips42's Avatar
you can make one out of a pair of needle nose vise grips. you notch out a section on the top jaw and weld a half a ball on the bottom. when you clamp together, the weld ball goes into the part you notched out. when you put something inbetween and keep on doing it, it make a bead lika a bead roller.
Old 05-31-2005, 10:45 PM   #25 (permalink)
70/30 Racing
Rockwood's Avatar
hyrdo-spanner...
Steve Rockwood
92 G20 - PTD #73
Old 06-24-2005, 04:01 PM   #26 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
I've been interested in making something like this for a while, but this is so much more simple and is adaptable to diffrent size tubing. I wanted it for fuel lines, mine are rusting out and didnt want to rip the engine cradle out to install new ones. COOL TOOL!
For any of you guys interested, here is a link to the thred:
http://www.turboforum.net/forums/viewtopic.php?t=8460
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
Old 06-24-2005, 04:01 PM   #27 (permalink)
SENTRASER's Avatar
Grr...you gotta register to view it, but its worth it!
Old 06-24-2005, 04:05 PM   #28 (permalink)
SENTRASER's Avatar
http://www.beadform.com/beadform2.html
http://www.beadform.com/beadform1.html
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old 07-12-2005, 12:30 PM   #29 (permalink)
Total Kokkass
I usually use any excuse to buy a tool, but for beading, I just go down to a local radiator shop. Depending on how they feel on a given day they will usually bead whatever I have for $5 or even free.
OECBen is offline   Reply With Quote
Old 08-02-2005, 01:34 AM   #30 (permalink)
I Keep It Unique
Trader Rating: 24 (100%)
My dad and I run a fire sprinkler repair and service company we have a tool thats called a roll groover that we use on joining water supply pipes for the sprinkler system basically its the same concept as the bead roller only it does it in the opposite direction, it makes a groove instead of a bead so when the hose clamp clamps down on the silicone coupler it pushes it down into the groove we put 200psi + of water on something like this all day long so it should work the same thats what im doing....
[b]Now metal fabricating, welding and powder coating. PM me with your needs!
sinistersntra91 is offline   Reply With Quote
Old 08-02-2005, 12:28 PM   #31 (permalink)
Total Kokkass
Originally Posted by sinistersntra91
...its the same concept as the bead roller only it does it in the opposite direction, it makes a groove
sounds pretty cool....did it use special clamps or hose? was anything put in the groove, like rtv or an oring or something?
Old 08-02-2005, 09:51 PM   #32 (permalink)
I Keep It Unique
no just a regular hose clamp the pressure from the clamp combined with the flexibility of the silicone hose couplers pushes the silicone down into the groove enough for the groove to grip the coupler. On sprinkler systems we usually use a special fitting to join the pipes together its the same concept as using 2 hose clamps and a coupler.
Old 08-03-2005, 01:27 AM   #33 (permalink)
From the land of Imports
be careful using a roll grooved end though - as it goes inside the pipe you start reducing the internal diameter of the pipe work.
also i can't quite see how the interal groove helps compared to an external bead - the bead is there to stop the hose clamp slipping past, where as an internal groove will only do so much.
sinistersntra91 - as you know a roll grooved coupling used on this type of end have an extra lip that goes inside the groove, holding the internal rubber gasket in place.
(by the way, I work for a sprinkler installation company on the other side of the world )
good luck though! I'm not running boosted so don't have any issue with beading pipes
nismotoy is offline   Reply With Quote
Old 08-03-2005, 08:34 AM   #34 (permalink)
I Keep It Unique
yeah but you dont reduce the internal diameter by much, and yes there is an extra lip that goes inside the groove but as you also know there is not a direct pressure on the groove with that coupling if you use a hose clamp its a more direct pressure on that groove therefore pushing the silicone down into the groove.
Old 08-03-2005, 12:50 PM   #35 (permalink)
Stuck on an island
LOL why dont you guys just skip the silicone cupplers and just use the victolic wont ever have to worry about a blow out btw im a Pipe fitter and used to do sprikler fitting during my apprenticeship
279 hp @ 17psi
Nx 2000 : It sticks to the road like bubble gum to hot asphalt
Nick is offline   Reply With Quote
Old 08-03-2005, 06:28 PM   #36 (permalink)
I Keep It Unique
extra weight ya dont need, plus they are kinda pricey
Old 08-04-2005, 07:25 AM   #37 (permalink)
sweet, i kinda see where your coming from with using that type of pipe end.
definitely a heavy fitting, damn shame - there should be some perks to the job....
Old 08-04-2005, 08:21 PM   #38 (permalink)
I Keep It Unique
yeah I agree
Old 08-07-2005, 02:33 AM   #39 (permalink)
Turbo-VVL finally
Still, the best suggestion sounds like welding a small bead at the end of the pipe....?
[off topic]
BTW-(sinistersntra91) do you and your father ever do goverment work?(davis-bacon)
chirpin4th is offline   Reply With Quote
Old 08-16-2005, 12:53 AM   #40 (permalink)
I Keep It Unique
[off topic]
Nope why?
