Old 04-15-2005, 03:30 AM   #1 (permalink)
addicted to speed
How is your work space illumenated?
I have used Sears spot lights, that are super bright but only last a few hundred hours even with 150w bulbs. Also the sears small flouresent with a hook, not very bright but its still on the first bulb
Blk Lbl is offline   Reply With Quote
Old 04-15-2005, 01:14 PM   #2 (permalink)
bla bla bla
I have 3 36" hanging lamps, drop lights, all that stuff, it can be pitch black outside, and I could land an airplane down my alley
2003 VW gti 1.8t
72 Datsun 510-sold
Old 04-15-2005, 04:06 PM   #3 (permalink)
The more sensitive me
erick212's Avatar
Me and a few friends rent out a 3200sq foot building and lighting is a huge problem. We have big a$$ light in the roof but, that is 25 feet up and does not do a good job. In my section I have 4 4' florecent lights but, what I am planning on doing is having 4 more light on a system that swings out from the wall directly over my bays. I also use a few clip on lamps and a drop light. I think from working in my garage before we got the shop I can change a motor in the dark if I have to. It was a one car, really small and it only had one outlet that was not rated for much.
Bitch'n Heavy and doing nothing
06 Frontier - tow truck
92 Sentra se-r - boost
95 200sx se-r - the low budget booster... Running
low post count=working on cars more than computers
SR20deep Ct.
www.savagefighter.com
erick212 is offline   Reply With Quote
Old 04-15-2005, 04:36 PM   #4 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
Thats pretty much what I use. Hey it gets the job done
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 04-15-2005, 07:44 PM   #5 (permalink)
No soup for you
Trader Rating: 30 (100%)
We have six 12 ft. flourescents running down each side of the shop, two gimungo HID lights that look brighter than daylight in the center of the shop, a 12 ft flourescent along the back wall and a 4 ft. flourescent over the welding table. This is in a 3800 sq. ft. shop.
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 04-15-2005, 10:15 PM   #6 (permalink)
YEA, WE CAN DO THAT
i have a oversized one car garage, and it has a 12- 2'X2' flourescents with diabolical deflectors, i was actually plannin to make the entire ceiling full of lights, but that would create a problem with the attic space i also have 2 portable flourescents 6 500 watt halogens all portable tree type stands that barely see use, and 3 500 watt halogens that light the area in front of the garage (drive way) o and one 500 watt halogen floor model also portable. i have NO problems seeing anything....
94xe-r is offline   Reply With Quote
Old 04-16-2005, 12:22 AM   #7 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
LED "head-lamp".. 2 LEDs strapped to my forehead with elastic! Works great.
Either that, or a standard single-bulb shop-light incandescent thing.
Old 06-16-2005, 05:38 PM   #8 (permalink)
I have 4 dual 8ft Flourescent lights, 1 dual 4 ft flourescent lamp, and 1 80w lamp in a 24x24 garage. No issues with lighting here.
Shift_twisted is offline   Reply With Quote
Old 06-17-2005, 12:50 PM   #9 (permalink)
Like this.
http://www.nissanperformancemag.com/november03/garage/
4 sets of 8 foot long fixtures. In the cold they take a bit to "warm" up but not nearly as bad as t12 bulbs.
david is offline   Reply With Quote
Old 07-08-2005, 01:25 AM   #10 (permalink)
Classic Original Owner
Keep away from those incadescent drop lights. Very dangerous. A drop of gasoline on an incadescant lamp will turn it super nova. Many people and shops have been lost losing them. If you must use a drop light, use a low voltage neon lamp. They stay cool and won't implode.
racer29 is offline   Reply With Quote
Old 07-11-2005, 12:33 AM   #11 (permalink)
<-- The sun
Need Pictures Hosted?
http://rnaodm.cjb.net/
Randomletters is offline   Reply With Quote
Old 07-12-2005, 12:25 PM   #12 (permalink)
Total Kokkass
When you choose your lights remember to consider the power you have available. If you only have a couple 15 amp 110 volt (~1500 watt) circuits in your garage, halogens or incandescents can max out your power pretty quick. Fluorescent will generally use less power to light the same area.
OECBen is offline   Reply With Quote
Old 07-19-2005, 10:09 PM   #13 (permalink)
OECBen and racer29 have good points. A cheap way to go is to use one of those $2 clip lights and use the largest compact fluorescent bulb you can find in it. I think you can get a 27W CFL and it's equivalent to something like a 150W incandescent, with less heat
MaxSE-R_VA is offline   Reply With Quote
Old 07-19-2005, 10:11 PM   #14 (permalink)
Forgot to say down side is if you drop it you'll probably bust the $10 bulb
Old 07-20-2005, 11:19 AM   #15 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
Ive got about (8) 2x2 drop in fluorescent units in a 1200 square foot area. I scored a bunch of these at auction (300 of them for $8, yep, thats $8 for ALL of them) one day so Ill probably add more when I get around to it. These ones are meant for suspended celings, so I just hung the celing track and dropped them right in.
BTW: Ive still got well over 200 of these light fixtures, an open inviation to anyone that wants to come and pick up as many as you need. Id love to ship them, but they arent light (ba dum bum!)
Old 07-20-2005, 11:27 AM   #16 (permalink)
erick212's Avatar
^^^^^^^^^ holy dry humor Batman ^^^^^^^^^ I need a drink after that "joke".
Old 07-23-2005, 03:38 PM   #17 (permalink)
70/30 Racing
Rockwood's Avatar
current 2 car garage has 2 4x4' fixtures and a 2x4' fixture, flourescent, obviously. for drop lights, i only use the flourescent ones, the incandescents burn out if you breathe wrong. even with the three fixtures, it is entirely too dim in there, and when the hood is up, it blocks one of the fixtures.
the new garage is ~1400 sq ft and has 9 or 10 4x4' fixtures, plenty of light.
another thing that helps lighting a lot is a coated floor, especially under car lighting.
Steve Rockwood
92 G20 - PTD #73
Rockwood is online now   Reply With Quote
Old 07-25-2005, 05:04 PM   #18 (permalink)
yeah, for under car lighting, I havea 4x2 flourescent light mounted on tiny casters, that sucker will light up the entire underside of the car
Old 07-25-2005, 05:49 PM   #19 (permalink)
easy 400WHP
Trader Rating: 27 (100%)
damn.. I need to get me some flourescent drop lights.. my 18V Craftsman Flashlight does real good.. but i usually kill the battery before I finish any real work...
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
Old 08-17-2005, 10:21 PM   #20 (permalink)
I kind of like the idea of the 4' flourescent under the car. I may try that.
