when i had to clean up some oil and tranny fluid stains on the driveway, i used some pool acid. i believe its called muratic acid or something like that, anyway it picked up everything. i just diluted it with a little water in a bucket, used a scrub brush and rinsed it off with a hose. it came out really good almost like new. just be careful not too inhale the fumes if at all possible...
Kitty litter will absorb the spill so that you may scoop it up after. As for the stains, we use this orange stuff (Orange Blast, I think) sold in the automotive section at walmart. Just soak the stain with the orange stuff, let it sit for a while, and rinse it off with the hose. Most of the time it works but if it's a really dark and old stain, it takes two washes.
Simple Green automotive degreaser. Spray it on REALLY heavy, let it soak a while and evaporate. Also spray it on, let it soak, and scrub with a brush or something too.
if the oil has been there a while mineral spirits or paint thinner should get it up pretty good but dont use it around blacktop you'll have a mess then :P
Larry Low
