Old 06-16-2005, 09:21 AM   #41 (permalink)
Geo I am a moderator
NISsport
Geo's Avatar
Originally Posted by OECBen
Don't listen to Geo, when he started working on cars they didn't even have AC current. ;-P
Yeah, when the spokes busted, we had to carve them out of a tree and after we installed the new one, we had to soak it with water to make it swell and lock in place.
Besides, you know me and electricity. Shoot, I don't even listen to me when it comes to electricity.
Dude, how've you been? It's been a long time. I've been meaning to call for a long time. I did actually call once about 6 months ago and y'all weren't home. How are you doing?
George Roffe
91 SE-R (well modded)
http://www.nissport.com
Geo is offline   Reply With Quote
Old 06-16-2005, 09:52 PM   #42 (permalink)
70/30 Racing
Rockwood's Avatar
i got my 6/3 from Home Depot. yes, it was expensive, but the wholesaler wasn't open until tuesday (some holiday weekend) and i needed to do some welding. i replaced the power wire on my welder with the extension chord, so now the welder plugs directly into the wall up to 30' away...
Steve Rockwood
92 G20 - PTD #73
Old 06-16-2005, 10:55 PM   #43 (permalink)
oh so LAZY
Will's Avatar
Originally Posted by Rockwood
i got my 6/3 from Home Depot. yes, it was expensive, but the wholesaler wasn't open until tuesday (some holiday weekend) and i needed to do some welding. i replaced the power wire on my welder with the extension chord, so now the welder plus directly into the wall up to 30' away...
I hope it is a really heavy duty extension cord. I cant even run my wire welder on and extension without it overheating.
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 06-16-2005, 11:06 PM   #44 (permalink)
70/30 Racing
Rockwood's Avatar
its a 3 wire 6 AWG wire dude, not a regular extension chord.
Old 06-17-2005, 03:18 AM   #45 (permalink)
oh so LAZY
Will's Avatar
Sorry, just had to check.
Old 06-17-2005, 09:05 AM   #46 (permalink)
Total Kokkass
Not trying to be an ass here...just an FYI for anyone who might be interested...
Cable is generally refered to by its wire guage and number of conductors (wires). So the 6/3 we were discussing contains 3 conductors, each of which is 6 gauge (AWG). Most welders will use 3 conductors, but can be wired using a 4 conductor feed. The new standardized dryer outlet has a 4 prong plug. (Maybe someone out there can provided some info on the ins and outs of 220V common and ground wiring and going from 4 to 3 conductors)
For extension/welding cords, you generally also want flexible cable (each conductor made up of many small strands) with a jacket (covering) that is oil and solvent resistant. Most cable will have all of this information printed on the outside. If you look at the pics narcotix put up, it is marked 'SEOOW" which indicates it is rated for
(S) hard service
(E) has thermoplastic inner and outer jackets rated for 600V usage
(OO) both of which are oil resistent
(W) and its is suitable for outdoor use.
The only other common letter you will see is a 'J' in place of the 'E' (i.e. SJOOW) which means its jacket is rated for 300V usage.
OECBen is offline   Reply With Quote
Old 06-17-2005, 09:26 AM   #47 (permalink)
SR20JET POWERED!!!
^^ what an ass....
95 SE-R-SOLD
93 SE-R-RIP(rusted into pieces)
93 SE-R-SOLD
92 SE-R-SOLD
89 Civic drag car
94 G20
Xse-rX is offline   Reply With Quote
Old 06-17-2005, 02:18 PM   #48 (permalink)
Cheap Bastard
narcotix's Avatar
Cable is generally refered to by its wire gauge and number of conductors (wires). So the 6/3 we were discussing contains 3 conductors, each of which is 6 gauge (AWG). Most welders will use 3 conductors, but can be wired using a 4 conductor feed. The new standardized dryer outlet has a 4 prong plug. (Maybe someone out there can provided some info on the ins and outs of 220V common and ground wiring and going from 4 to 3 conductors)
(S) hard service
That's some DAMN good tech right there, fellas. The only other thing I would add is that if you're going to make an extension cord this long with this cable, make sure to make a good, heavy duty hanger to coil this up onto. I made a small bracket to lug 20+ of cable around and bolted it onto my roll-around TIG machine.
"Better living through chemistry...."
narcotix is offline   Reply With Quote
Old 06-17-2005, 05:25 PM   #49 (permalink)
70/30 Racing
Rockwood's Avatar
this wire conducts better and is more compact anyway. since electricity travels on the surface of a wire, having many small strands is a lot better than a coupe of thick strands.
Old 06-18-2005, 08:45 PM   #50 (permalink)
Total Kokkass
<ASS type=complete>The skin effect varies depending on many factors. DC and low freq AC have very little skin effect...i.e. the 'flow' is spread more evenly across the entire cross-section.</ASS>
XassX
Old 06-19-2005, 12:49 AM   #51 (permalink)
Traitor in your midst
Originally Posted by Blk Lbl
So how many of ya'll have them? What kind, and would you by one again if you had it to do over?
I'd recommend that you get a friend who has one and then buy him beer. We have a MIG and a TIG and they sit idle a lot, but when you need it, damn is it convenient.
You could always look used and lower the barrier of entry. We got our TIG that was an old Hughes aircraft unit. Sure it weighs 1200 lbs, but I can build Jet wings! Or I could if I had any skill at it. Damn, how'd I get roped into splitting this thing 50/50?
-Jim
SE-R Cup Hooligan
Jim #98NX is offline   Reply With Quote
Old 06-20-2005, 11:52 AM   #52 (permalink)
Sportbike fevah
Having owned a MIG for private and amateur professional use,
I can say that saving a few hundred bucks isn't worth the lack
of capability in a crappy machine.
My first welder was a wallyworld special - cambell-hausfield flux core.
It sucked. BUT, learning to make a relatively clean bead on it
made the transistion to a better machine lovely.
My second welder was a Miller sidekick 90. It required a
some refurbishing, but the price was right - 50 plus about
100 in parts.
I've been thinking about picking up a new welder for the last
couple of months, and after reading through this thread and
the one about welder's under 400, I realized that I can't live
without one. I already have a gas and wire, having recently
lost the other welder through a parting of ways with my old
partner.
Anyway, I thought that bang for the buck, I liked this one the most.
It will do all the IC/exhaust piping I ever want to do, and handle
quite a bit of rugged tube framing. 1/4" max thickness, but I rarely
want to weld anything thicker than that, and if I need to weld
something really thick, there are tons of oldschool stick welders I
can borrow around here.
Anyway, thanks guys, for having these great two threads about
welders, they really solidified my plan, and answered a bunch of
questions I didn't know I had.
Peter
'91 SE-R track slut w/ VE
'02 G20 Sport
'95 Yamaha FZR 600
peter.serwe@gmail.com
Peter is offline   Reply With Quote
Old 06-20-2005, 11:58 AM   #53 (permalink)
Sportbike fevah
Almost forgot to mention, here's the specs in PDF format.
Old 06-20-2005, 12:35 PM   #54 (permalink)
Turbo-VVL finally
I'm not sure what the difference here is-- I use gas no matter what....
And my mig is a wire welder.
Quote: (Originally Posted by Rockwood)
MIG is pretty portable too. you don't need a 100lb tank or anything.
just make a welding cart. that's what i did. great way to learn to weld too...
Yeah, we dont have a MIG at the shop though. I just have my wire welder and we have a big TIG that I made a really nice table for with wheels.
b13-sr20ve
I'm one crazy mo-fo, I had to buss a cop *** he wouldn't give me my props in Oak-town.
chirpin4th is offline   Reply With Quote
Old 06-21-2005, 09:56 PM   #55 (permalink)
I love Katamari
maybe he's referring to a seperate spool/power source system - the one my instructor uses while working at Ziegler/CAT uses drums (not spools) for the flux core wire
save the whales, harpoon fat chicks
Bjorn is offline   Reply With Quote
Old 06-22-2005, 03:44 AM   #56 (permalink)
70/30 Racing
Rockwood's Avatar
lol. 1200lbs? nice and portable. you guys have a forklift for it...?
you going to build the next spruce goose, except out of 1" thick steel?
Old 06-22-2005, 03:52 AM   #57 (permalink)
oh so LAZY
Will's Avatar
Ha, spruce goose, did that thing ever fly? I cant remember. Steve, remember the manifolds we spoke about? check the new vendor.
We have one TIG at the shop, it actually gets used every single day. Personally, if you are only using it once in a while in your home garage, I would not get any more than an inexpensive MIG from Harbor Freight. just my opinion.
Old 06-22-2005, 04:06 AM   #58 (permalink)
NISsport
Geo's Avatar
Indeed it did. I cannot remember exactly how high or how far, but that fat ass (bigger than mine!) got out of the water and flew. And if you ever get a chance to see it, that is one truly awesome aircraft!
Old 06-22-2005, 08:36 AM   #59 (permalink)
SE-R RACER
dominojd's Avatar
Here are some pics of what you can do with a cheap welder. This is pretty much the capacity of the welder(3/16) but it worked fine. Hey Geo I sent you these pics and don't know if you ever got them. I lenghtened the rear struts to get more droop and made the tabs wider to avoid tire rub.. Oh BTW the welder is A Farmhand 115or 125 I forget which one. It is sold at Tractor supply. I bought this sucker around christmas for around $260 with a kit of extras. It came with cart,mask,sleeves,gas regulator,chipping hammer,wire brush and some test wire.
Joe DiMinno
SCCA ITA/NASA PTE Racer
"Fast cars don't make fast drivers"
First and Only NASA National SE-R CUP Champion
www.Kakashiracing.com
CRAZYJOE@Kakashiracing.com
dominojd is offline   Reply With Quote
Old 06-22-2005, 02:40 PM   #60 (permalink)
NISsport
Geo's Avatar
Hey Joe. Cool deal. Never got the pix (that I can remember). I've got an upgrade coming. I think you'll like it. I just have to get a couple of other things done first though. With the transition to the new shop I've taken over most of the shipping so I'm slowed down a bit.
BTW, can you e-mail me your address again. I sent you something that got returned for insufficient address and I thought it was correct.
