Old 06-22-2005, 04:19 PM   #61 (permalink)
70/30 Racing
Rockwood's Avatar
Originally Posted by dominojd
clean your metal more first. i use brake cleaner to make sure there arent many impurities on there.
i assume your welder is turned all the way up, now you just need to turn the wire feed down. looks like it was spitting.
either that, or you were smoking while welding again...
Steve Rockwood
92 G20 - PTD #73
Rockwood is online now   Reply With Quote
Old 06-22-2005, 04:27 PM   #62 (permalink)
70/30 Racing
Rockwood's Avatar
hey guys, is there any difference between straight Argon and Argon/CO2?
Old 06-22-2005, 04:30 PM   #63 (permalink)
Sportbike fevah
Yes. For aluminum, you run straight argon. For mild steel, you
run C25 which is 75% argon, and 25% CO2. For stainless, you
run a mixture of mostly helium, some argon, and IIRC, 5% CO2.
You of course change wire as well.
Peter
'91 SE-R track slut w/ VE
'02 G20 Sport
'95 Yamaha FZR 600
peter.serwe@gmail.com
Peter is offline   Reply With Quote
Old 06-22-2005, 05:13 PM   #64 (permalink)
70/30 Racing
Rockwood's Avatar
hmm.... hopefully they gave me a mix...
i have never actually asked in all my time welding, lol. probably refilled that bottle like 20 times.
Old 06-22-2005, 10:21 PM   #65 (permalink)
I love Katamari
as said, argon only for Al. I've also used straight argon for mild and ss, though I've heard that tri-mix is much more forgiving than argon at ss. Also, CO2 generally gives deeper penetration for the same bead width compared to straight argon
save the whales, harpoon fat chicks
Bjorn is offline   Reply With Quote
Old 06-22-2005, 10:51 PM   #66 (permalink)
You guys should check out Welding Technology Fundamentals by William A. Bowditch and Kevin E. Bowditch http://www.amazon.com/exec/obidos/tg...books&n=507846
It's the book we used for the welding class I took at a local community college. It covers all different kinds of welding, including MIG, TIG, and oxy acetylene. Its great book whether you know nothing about welding, or to just use as a reference. Its got charts on stuff like what type of shielding gas to use, what filler rod, etc.
Old 06-23-2005, 06:10 AM   #67 (permalink)
SE-R RACER
dominojd's Avatar
Actually this is the one I had to grind out the weld and redo. I had the polarity set backwards and didn't figure it out until I was already done with it. The other one was already on the car so I didn't take pics of it. That one came out almost perfect. That is where the spitting came from. sh*t these were only the second thing I ever welded.
Joe DiMinno
SCCA ITA/NASA PTE Racer
"Fast cars don't make fast drivers"
First and Only NASA National SE-R CUP Champion
www.Kakashiracing.com
CRAZYJOE@Kakashiracing.com
dominojd is offline   Reply With Quote
Old 06-23-2005, 11:15 PM   #68 (permalink)
Cheap Bastard
narcotix's Avatar
I like how this thread gets longer and longer....its the SR20 Welding info thread by now..
Anyways, this little gem of a forum answers alot of the questions here. Check it out:
Miller/Hobart Welding Forums
-Jimmy
"Better living through chemistry...."
narcotix is offline   Reply With Quote
