Old 08-24-2005, 02:05 AM   #1 (permalink)
Oil Cleanup
Hi fellas. I bonked today and got a huge puddle of oil on my garage floor. The floor is concrete. I cleaned up the slick with like 4 rolls of paper towels but the surface stays greasy no matter how much i wipe it. Also it left a brown stain. How do i get rid of the stain .
Thanks for any help any of you can provide.
Old 08-24-2005, 02:11 AM   #2 (permalink)
EECS Nerd.
kitty litter (seriously)
Old 08-24-2005, 02:12 AM   #3 (permalink)
I used Castrol Super Clean. Spray, scrub, soak, then rinse. If you can get hold of pressure washer, that would be even better.
93 SE-R, PaceSetter header+exhaust(cut and with extra resonator), AEM CAI, Hypercoil 2, AGX, AD22VF brake upgrade, Goodridge SS brake line, silver 15" ATS Comp Lite with 205/50-15Kumho ECSTA 711.
Mada is offline   Reply With Quote
Old 08-24-2005, 02:22 AM   #4 (permalink)
Blast From The Past...
Trader Rating: 23 (100%)
Anytime I have to clean an oil stain off of concrete, I use swimming pool acid. Work's like a charm but, becareful the smell is a bit intense.
Eric?!
Support your Forum & Vendor's
SUPER"FAKA"MAN is offline   Reply With Quote
Old 08-24-2005, 08:06 AM   #5 (permalink)
Geo I am a moderator
NISsport
Geo's Avatar
I'd start by using some carb cleaner and see if that does the trick. If not, then use some of the harsher solutions.
George Roffe
91 SE-R (well modded)
http://www.nissport.com
Geo is offline   Reply With Quote
Old 08-24-2005, 11:12 AM   #6 (permalink)
dorina, yea, yea
This is what I use also.
Old 08-24-2005, 11:22 AM   #7 (permalink)
I had good luck with non diluted simple green just the other day on some oil stains. Used a brush to scrub the stains
Beat13 is offline   Reply With Quote
Old 08-24-2005, 04:55 PM   #8 (permalink)
OMFG WTF BBQ
walrusx4's Avatar
thrice here
I use it as well:
dump it on it, cover it pretty well, walk over it and grind it into the stain, let it sit for like an hour or more, then sweep it up.
~Dan
~Dan @ Boston
99' G20t
Old 08-24-2005, 07:48 PM   #9 (permalink)
Kitty litter to soak up the oil then if you have a stain try engine degreaser let it sit for a few minutes scrub it a little if you think it needs it then hose it off. I always get a few drips on the driveway when I'm changing oil/ other fluids and the engine degreaser works great for me and it's only like 97 cents a can at walmart.
Originally Posted by hbkorkut
where i come from there ain't no ebay
nik33615 is offline   Reply With Quote
Old 08-24-2005, 08:12 PM   #10 (permalink)
70/30 Racing
Rockwood's Avatar
Don't use engine degreaser unless you want your garage to smell like it for a long long time.
I use Castrol Super Clean or Revive-a-Drive. Both work really well.
Nothing short of muriatic acid will completely remove it.
Steve Rockwood
92 G20 - PTD #73
Old 08-24-2005, 09:05 PM   #11 (permalink)
^^^This is what I use for any oil spots and etc...^^^
Old 08-24-2005, 11:46 PM   #12 (permalink)
For some reason the generic engine degreaser they sell at walmart dosen't stink as much as most others I have tried like gunk or the advance auto brand.... I do know what you mean about the smell though!!!
I usually get small oil spills on the driveway so the smell isn't an issue for that use since it's not in an enclosed area.
Old 08-25-2005, 07:17 PM   #13 (permalink)
bla bla bla
yep, I use carb cleaner or brake cleaner...
2003 VW gti 1.8t
72 Datsun 510-sold
Old 08-25-2005, 09:58 PM   #14 (permalink)
SR20DEbT
Trader Rating: 53 (100%)
My dog usually licks the oil stains up for me. Lol, jk. I use kitty litter and if it doesn't work I use the strongest smelling household chemical I can find to take care of it.
-Bes
92 Sentra GTi-R
Small Snail Crew
----BNB----
Old 08-26-2005, 02:19 AM   #15 (permalink)
VVL Nut
I just use the orange hand cleaner on the stains, cleans them up for me just fine. Doesnt smell like a chemical dump either.
98 200SX SE
SR20VE
200SXSE is offline   Reply With Quote
Old 08-26-2005, 03:00 AM   #16 (permalink)
REV it up!!!!!
daxx's Avatar
Trader Rating: 36 (97%)
yup muriatic aid for hardcore cleanups will do the trick. I use kitty litter to absorb the oil then simple green....
This is for you dad!!!In Loving Memory of JJR,09/23/2006.>>>CAPT. REV
U.I.O.G.D.
SR20DEEP in Vegas
96' SE-R Patience is a Virtue - Full all out wizadry on this build
Pro-tech Design
The Few, The Proud..The NRR
daxx is offline   Reply With Quote
Old 09-08-2005, 08:50 PM   #17 (permalink)
Down to One B13
Kitty Litter (cheap, generic, non-scented) or "real" Oil-Dry, they're both the same absorbent clay stuff. Dump it on the area and grind it in by twisting your shoe on it. It will crumble and absorb better. Sweep it up. As a final pass, spray the area down with brake cleaner or other solvent; let it penetrate a minute or so, and do the clay stuff again.
If you use the acid, wear a GOOD respirator and have ventilation. The acid will actually dissolve the top surface or the concrete a fraction of an inch deep, REMOVING the stained material.
-Wayne
WOT2000 is offline   Reply With Quote
Old 09-13-2005, 07:18 PM   #18 (permalink)
Griots Garage sells some environmentally friendly concrete cleaner...
http://www.griotsgarage.com/catalog....3080&SKU=11284
- Greg -
MrFancypants is offline   Reply With Quote
Old 09-13-2005, 11:45 PM   #19 (permalink)
party over there
AG>SR's Avatar
Trader Rating: 40 (100%)
.......go to your local pay'n'spray carwash with an engine degreaser button........take 2 large empty gatoraid jugs and fill 'em' up........great for use with a ghetto-parts washer (5gal. bucket).......$.02,Jason
random music
more random music
and beeee veeeeerrrry
AG>SR is offline   Reply With Quote
Old 12-20-2005, 11:53 PM   #20 (permalink)
The Genesis
how would u go about using this muratic acid(i know its for pools)..i mean, do u let it sit, or do u apply to the oil stain and then scrub it? i fu*ked up my parents driveway pretty bad *** all the oil leaked out of my car so it stained the WHOLE driveway, i used some pretty strong degreaser we use at work and scrubbed it, but it didnt really do anything..so im thinking the acid would be my best bet
