guys im trying to get some oil stains off of my driveway i have tried brake cleaners and scrubbing but they dont come out are there tips or tricks you guys use to completely remove the stains?
99 i30- lowered on 20's, jdm evolution kit
02 sv 650s- v twin scorpion high mount full fairing candy blue
07 RX8 turbo-apexi coilovers, mazdaspeed body kit, 19x9.5 all four corners
if the oil stain is fairly new <= 24 hours you can use a product called "zip wax" that will generally take it out, HOWEVER if its on rough concrete you will probably be stuck with it, if its on smooth concrete(e.g. garage floor) you can use gas put it on a rag and wipe away and it should come out, then finish it off by rinsing it off with water
remember gas is flammable and the vapors are explosive USE with CAUTION
lates
joe
g20 mods
- front and rear stB that i made
- LCAB that i made
- battery in the trunk
- OBX Header
- Thule Bike Rack
- Fidanza Flywheel
- Unorthodox racing pulley set
- Short Shifter -- with my old 300zx shift knob
- Apexi TT
- JWT s3 cams
- ADDCO sway bar
- P11 12 spoke 15" wheels
- Tinted windows
- Infinity Speakers 4x6 F, 6.5 R
- Hotshot CAI
heres what i used to do in the shop... put down cat litter/ oil absorb let it sit a while and then rub it in with your shoe.. I mean really grind it into the concrete... then brush the excess off and let it sit overnight .. next day hose it off... if its still there, then go to Autozone and pick up a gallon of concrete cleaner...
........what I do is the kitty litter as mentioned, then run to the self-service car wash and fill a gallon jug with the 'engine-cleaner' pour it on and cover with an old towel and let sit for the day, spray it off/out the next day...........
..........gear oil DOES leave a slight ghost..........thats the low-buck way, but you get what you pay for and use as directed, ambient temp is the biggest factor, Jason
and beeee veeeeerrrry
caustic soda work the best, eats oil and grease, read the instructions and warnings on the product... i cant stress that enough.
and it will eat paint ect and what ever else it gets on, so be careful, we use it to clean the workshop floor once a year. come up a treat, then paint it.... saves the oil stain on the concrete. in the future
theres also a thing called driveway restore. ou pour it on and it turns to like a sawdust texture you sweep and the concrete is clean.http://www.pour-n-restore.com/oilstain.htm
i just cleaned my oil stains (that were about 9 months old) by using a cup of that soaking slution you can buy at ur local auto store (chemichal carb cleaner/parts wash) put that down scrub reall nice for a good 10 min then put about a cup of gasoline down..... scrub away then get some paper towels and pick up everyting.
then get a cup of tide or some sort of detergent and repeat the process it worked wonders for me.!
