I bought a rapid pump jack on ebay(same as harbor freight). It was used and is low on oil. Is it OK to use brake fluid in it? Refilled it and bled it accordingly and it seems fine but not sure if its exactly how it should be, seeing as it never worked properly. Any input is appreciated.
Well, I still have brake fluid in there and it holds pressure fine. I bought hydraulic jack oil but I guess thats different from the fluid, cause it didnt work hah.
